Hi all,
I am having trouble figuring out how to accomplish this and would very much appreciate any help.
I am trying to add an audio track to an existing video file while keeping the original audio track as well. However, I want to insert the second audio track in a specific location of the video. The 2nd audio track is much smaller and is just some music I wish to add during the video.
I wish to do this for XViD at this time, but would also like instructions if possible for mkv's as well in the future.
I also want to make sure I am not reencoding the video and losing quality in the process.
Any help would be truly appreciated. Thanks very much for anyone's time.
I would:
1. load up the current video file (with current audio) into an NLE
2. load up the music audio file also
3. align the music audio to where in the timeline you want it to start and adjust the relative balances between the main audio & music
Then, depending on whether you want to have 1 remaining audio stream (both main+music blended into one), or 2 (where they would be selectable), you would do either:
A. Mixdown the entire program length of both audio tracks to new audio file, and remux the video, replacing the audio.
or
B. Mixdown the entire program length of ONLY the music audio track to a new audio file (even though there might be HUGE sections where it is silent), and mux in the 2nd audio stream to the current video + audio.
This will retain as much of the current quality as is possible (depending on which way you go)...
Scott -
Adding a second audio track to a DVD-R
By danielmak in forum MacReplies: 1Last Post: 30th May 2010, 21:31 -
Adding A Second Audio Track
By DeathStalker77 in forum Authoring (DVD)Replies: 0Last Post: 11th Aug 2009, 01:16 -
Adding a 2nd audio track to established videos
By madison13 in forum Newbie / General discussionsReplies: 4Last Post: 8th Feb 2009, 23:39 -
Adding an Audio/Music Clip into the main Audio Track?
By Moontrash in forum EditingReplies: 3Last Post: 20th Nov 2007, 17:45 -
Extracting 2nd audio track from avis
By guy with a stick in forum AudioReplies: 1Last Post: 18th May 2007, 21:54
