How can I convert 20/24/25/30p videos to 50/60p for smoother playback?
I tried Premiere Pro CS5.5 but couldn't do it.
I want something like Splash Pro Motion2 that makes videos play smoothly =(
Results 1 to 30 of 35
http://www.kiva.org/about -
Each camera like Canon 500D/550D/600D...
Or HD videos from Youtube or ripped mkv videos...
Here's the sample: http://mirillis.com/en/products/picture2.html -
That sample wasn't smooth either, just "smooth-er", still juddering tho.
Hi P.J,
Its very easy. look here: http://www.spirton.com/convert-videos-to-60fps/
Awesome smoother playback:
Original: http://www.spirton.com/uploads/InterFrame/20110618-Sample-Original.mkv
Converted: http://www.spirton.com/uploads/InterFrame/20110618-Sample-InterFrame.mkv
Claudio -
I saw deeper colors, from frame doubling, but smoother? I can understand AviSynth / Lagarith interpolating 60i to 60p, and that works well, but that's because there's a difference between frames to work with.
30p has NO difference between frames, so frame doubling is the only thing you can do, and that does produce deeper color, but I don't see how it can be smoother.
Educate me then! Thanks -
60i to 60p is same thing as bob deinterlacing (double rate deinterlacing) - essentially each field (which represents a unique moment in time) becomes a frame .The temporal information is there to begin with
Frame doubling isn't the "only" other thing, you can insert blended frames as well30p has NO difference between frames, so frame doubling is the only thing you can do, and that does produce deeper color, but I don't see how it can be smoother.
But this refers to a 3rd method: motion interpolation, or optical flow. The "inbetween" frames are newly synthesized from looking at motion vectors from the adjacent frames . It's not the same thing as a dumb blend or duplicate -
Yes, interpolated. Interframe is just a function based on mvtools2 , which does the actual heavy lifting
avisynth is free way to do this. Other plugins and software can get very expensive e.g. nuke, shake, after effects (timewarp, pixel motion); plugins would be twixtor (versions for final cut, premiere, vegas, avid mc...)
But there are lots of potential problems with interpolation, like edge morphing artifacts. It really depends on the type of content. Some interpolate well, others are horrible. The "pro" software have more advanced features like edge mattes and track guides to improve the interpolation
I posted some other comparisons and explanations before; Here is one (it's a slo mo example, but the concept is the same between the 3 methods the "inbetween" frames are either generated by 1) duplicates 2) blends or 3) motion interpolated ; if you played it at faster speed, the interpolated version will still look the "smoothest"), you can download the comparison in post #3
https://forum.videohelp.com/threads/340910-looking-for-s-w-that-can-recreate-an-MP4-fil...peed?p=2121826
Yes , the concept is the same. Eitherway you are generating "in between" frames. So you can either use that for smoother slo mo, or for smoother normal speed playbackSo can that be slomoed as in undercranked as 30p?
The idea is as if you shot an actual higher FPS -
Thanks. I tried Pixel Motion and TimeWarp in AE but looks strange while changing scenes =(
Cool, maybe there is a "free lunch". I know there's no real perpetual motion machine, but a reasonable facsimile can do, I'm not a Hollywood pro.
Thanks everybody! -
So the GoPro was picked out for minimal motion in that scene, and let the viewer assume what they will, right? I get it. That's all part of the craft, yeah? Over here on the DARK SIDE, Mwahahahahahahahahahahahahahahahahahahaha.
Hey, I need a little help with Avisynth.
I got it installed OK per directions, but it's trying to de-interlace my input video which is 30p, and ends up crashing, so I took that line out of the script and it gets past the video preview OK, but then it crashes again.
So I'm thinking this script only works on interlaced video?
"All F'd Up On The Dark Side" -
ahhh poor wittle budwzr hurt his brain...
Don't give in so easily (I did too for the first few years). It's just a tiny learning curve
avisynth is a free goldmine for various video processing and manipulation
It can do things that no other program (even $10,000 ones) can do
Embrace the dark side
OK, hahaha, but the script provided at the website has deinterlace involved and I don't have anything interlaced anymore. And Avisynth comes in 64 and 32 bit installs, which is fine, but that 60fps script seems to only work in 32 bit mode.
OK, let me fool around a little more. Thanks for the encouragement, I really WANT to get a handle on it because I know it's good. Same as Blender, but my brain is so stuffed right now.
But I wanna be on the darkside too. -
Hello budwzr,
This is normal. I always ask for help on videohelp with avisynth scripts (Hello Jagabo, Poison)
My files are 30fps progressive (Saturn emulator captures). My script to this is (Windows 7 64bits):
Work flawless. try it.AVISource("VIDEO.avi", audio=true).AssumeFPS(30.000)
Setmemorymax(1024)
SetMTMode(2,7)
PluginPath = "C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\"
LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\mvtools2.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\RemoveGrainSSE3.dll")
Import("C:\Program Files (x86)\AviSynth 2.5\plugins\InterFrame.avsi")
ConvertToYV12()
InterFrame(Preset="Medium",FlowPath="C:\Program Files (x86)\AviSynth 2.5\plugins\")
Claudio -
Yeah, blender is fantastic too. They added motion trackers a few months back so you can do real 3d matchmoving now. Avisynth + Blender are freeware goldmines, with large user base and forums that can help out
Avisynth is a mess in terms of documentation & organization. Sometimes there are multiple versions of filters with the same name, but only a specific version of the .dll works !!! WTF.... But if you take the time to struggle through it , you will be glad you did. I avoided it like you for years, now I'm kicking myself for doing so. Trust me, even learning the basics is well worth the time investment -
If you have win7 64 bit, never mind, install everything 32 bit and you will give yourself a favor, Avisynth 32 bit, ffdshow 32 bit, Megui 32 bit, whatever it just works.
Download Mvtools2.dll from here here bottom of the page , unzip and put in Avisynth/plugins folder
for NTSC 29.97p I use this to slowdown 2x:
AVISource("D:\video.avi")
KillAudio()
ConverttoYV12()#video is RGB from frame server
super = MSuper(pel=2)
backward_vec = MAnalyse(super, overlap=4, isb = true, search=3)
forward_vec = MAnalyse(super, overlap=4, isb = false, search=3)
MFlowFps(super, backward_vec, forward_vec, num=60000, den=1001)
Assumefps("ntsc_video") #ignore this and youl will get double frame rate
for 30p (cameras):
Directshowsource("D:\video.mov")
KillAudio()
MFlowFps(super, backward_vec, forward_vec, num=60, den=1)
Assumefps(30) #ignore this and youl will get double frame rate
you have to use these for separate clips and such, if you try to slow down crossfade it will fail, so same scenes preferableLast edited by _Al_; 31st Dec 2011 at 11:38.
Sample files: Download contain 2 files 30p(original) and 60p(Remake)
link (20Mb): http://www.multiupload.com/5Z3SHI79I1
Claudio
60i to 30p without re-encoding?
By bobthegoat2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 30th Sep 2011, 08:55 -
splash
By skorpinok in forum Software PlayingReplies: 3Last Post: 31st May 2011, 09:49 -
Yes, Splash PRO is out!
By nitro1973 in forum Latest Video NewsReplies: 18Last Post: 4th Mar 2011, 06:44 -
Deinterlace 60i -> 60p, yes, 60p, not 30p.
By 123Mike in forum Video ConversionReplies: 20Last Post: 4th May 2009, 12:43 -
frame rates 24 30 30p 30i 60 60p 60i
By maxtrack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 28th Jul 2007, 16:21
