Hi,
I recently started a project to transfer a big bunch of VHS tapes for friends and family to the computer. So I need to figure out how to transfer multiple VHS tapes at once.
I have 5 separate VCR's and I want to somehow transfer the tapes without buying 5 separate computers.
Does anyone know of a solution for transferring VHS directly to a hard drvie without having to use the computer and simply use the computer for editing the files later on?
Thanks in advance!
Robin
Results 1 to 11 of 11
You probably COULD do it with one PC, but you don't want to. It would have to be so beefy to work, it would cost $$$$.
Much better to get 5 PCs, or 5 DVRs/PVRs (less setup finickyness, but an extra step 2 import).
Scott -
buy or rent 5 dvd-recorders
and for editing tell them to wait a little
or take the 2 better ones (vcr) and make one road to the pc and the other to dvd-revorder -
You can use multiple Hauppauge PVR 250/350 cards in one computer. These encode to MPeg2 in hardware.
Software control is the issue. BeyondTV PVR software can be set to record multiple tuners at once but controlled from a program guide. You may find a way to manually control recording.
If you go this route, best to split the record writes to multiple drives. Do not record to the C: drive.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
This simply is not going to happen.
Wishful thinking, but it's not logistically possible.Want my help? Ask here! (not via PM!)
Thanks, that does sound like an option I could use. What do I need in terms of a computer then. Will any new basic desktop computer do it? And does using multiple cards reduce the quality on the videos in any way?
Also I didn't completely understand waht you meant with "controlled from a program guide".
Love the help I'm getting,
Robin -
BeyondTV is a PVR that records TV from multiple tuners. It would need to be adapted for recording from VCRs.
The Hauppauge PVR cards encode to MPeg2 in hardware. They use very little CPU. The system stress is on the disc system not the CPU.
This is a job for a competent computer technician and may need a software script writer.Recommends: Kiva.org - Loans that change lives.
I'm transferring about 100 VHS tapes - pixellation problems
By mw01908 in forum Capturing and VCRReplies: 32Last Post: 15th Sep 2011, 01:05 -
Advice for transferring many MANY VHS tapes to external HDDs
By ryanwayne in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2009, 22:21 -
Transferring Old mini DV Tapes
By femtonitpicker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Apr 2009, 19:41 -
transferring old vhs tapes to computer for editing and burning to dvd
By michael109 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2008, 11:00 -
Newbie needs advice - transferring 8mm(camcorder) tapes to DVD
By KitKatluvr2 in forum MediaReplies: 4Last Post: 18th Jun 2007, 22:51
