My LG HX-806PE home theater actually has a setting in its menu for the region code. It asks me to enter 4 numbers to set a new code. It doesn't display the Region number currently set (nor the 4-digit code used at the moment), it just displays the letters HU. I suppose they mean Hungary, even though I'm in Bulgaria but it's the same region - 2. Anyway, I tried typing in 4 zeroes (0000), but that didn't change anything. So, anybody got an idea what 4-digit code I need to make it Region-free?
	The region setting you talk about is not the region setting for DVD region. It is used to set Parental Control (block certain content) in accordance to settings for your region.
 You can however try this:
 1. Switch on the device
 2. Open the DVD tray
 3. Press the (pause/step) button on remote once
 4. Press the "0" zero button 2 to 3 times, till a region menu appears. (Small block in the middle of the screen)
 5. Choose "0" zero for region free.
 6. All done. Insert any region DVD and enjoy.
 It worked for another LG model with amost the same model number, the LG HT806TGW. Even though this is a DVD home Theater system and your system is blu-ray, it doesn't hurt trying. If it does work, it will only be the DVD part that is region free, not the blu-ray part. Report back if it works or not.Last edited by Viking61; 28th Dec 2011 at 10:24.
	Well, well. At least we got it tested.
 If you want to know how to reset the password you mentioned in your first post, then look in the manual under 'Lock menu' in Setup.
	LG may have modified the hardware and/or the firmware on Toshist's model and that's why the hack no longer works. It happens all the time. Specialty players of all kinds such as DVD/VCR combos, TV/DVD combos, portables and home theater players have always been harder to unlock than normal standalone players.
	And I'd recently updated the firmware to the latest version (from October 2011) so I thought downgrading it and trying the trick again might work. I downgraded it to the oldest available (February 2011) but still couldn't hack the Region. Last edited by Toshist; 1st Jan 2012 at 11:31.
  Euroline DVD100 DVD Player Region all region code/hack?By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26
  Making a Region 1 Player Region Free. Can't find code.By KitanaAsh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Feb 2010, 09:28
  Region Code Samsung ht-bd1220 - Code does not workBy mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 15:44
  Need code for pioneeer bdp lx70 code for multi region ...By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 13:42
  Sony DVP-FX720 region restriction - using DivX waiting for region free codeBy wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
