Hello guys just wondering if anyone knows a good tool that encodes avi to mpv or m2v files using cce encoder. I tryed the film machine but it wouldnt let me add multiple avi files. Thanks
Well, CCE itself accepts multiple AVIs. I'm assuming you mean XviD and/or DivX-type AVIs. Have you tried opening any of them in CCE? You can also encode multiple AVIs frameserving via AviSynth scripts.
Or do you mean you're looking for some sort of an all-in-one-type program to do the work for you? If so, maybe try Avs2DVD. It uses HCEnc as the encoder which many believe to be the equal or even better than CCE. Check the link and website for more information. -
Thanks mate. Yea i meant to say i need all in one that creates avs script and then encodes with cce =) do those 2 programs you mentioned do that. Thanks
p.s i use avstodvd with hcenc but i make dvds at low bitrates so i need a tool that uses cce as i hear its better on low bitrates. -
All the front ends I know of for generating Avisynth scripts are part of a free software suite. Considering that CCE costs in the neighborhood of $1000 (US), I do not think you are going to find any freeware that generates Avisynth scripts for CCE.
Although djgazzabhoy is asking about freeware programs that work with CCE when using AVI sources, DVD Rebuilder (the free version) allows for the use of CCE for reencoding and shrinking DVDs and frameserves using AviSynth scripts.
compatible files
By woody12 in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jan 2011, 11:43 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Help with avs script to cce 2.7 for sports program
By JasonCable in forum Video ConversionReplies: 3Last Post: 1st May 2008, 08:03 -
Vista compatible program?
By smudger2468 in forum Video ConversionReplies: 4Last Post: 31st May 2007, 16:09 -
Want More Memory - Is This Compatible?
By daamon in forum ComputerReplies: 5Last Post: 5th May 2007, 09:19
