I've been trying to copy a VCD to another CD-R disk. Usually I use "CD Copier" with no problems, as it recognizes it as a VideoCD and makes the copy easily.
One of the VCDs I tried to copy had a few scratches on it, and could not be read on my computer. I tried copying the .dat file on the VCD to the hard drive on various computers, and finally found one that had a CD-ROM that could read the disk. Unfortunately, that computer doesn't have a CD-burner.
I know I can copy the .dat file on that computer, convert the file to an mpeg using VCDGear, and then transfer the mpegs to a computer with a CD-burner and reburn the VCD using VCDEasy or something like that... is there any easier way to do it?
Is there software that will make a VCD image that I could then transfer and burn easily? I tried making a disk image with Easy CD Creator, but that burned the disk in Joliet which doesn't work in the DVD player.
Thanks much!
Results 1 to 1 of 1
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 15:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29 -
VCD to DVD with subs - subpictures below video-image - Help?!
By nbarzgar in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jun 2007, 11:44
