Can a bluetooth device be hooked up to a PC or TV and be used in place of a speaker? If so, is there a specific type I should be looking for? Because I see drivers and sales rep talking in them and doubt those are for entertainment.
http://www.kiva.org/about -
I feel there is something missing. The bluetooth package I looked at only has the earpiece itself. What other thing am I suppose to get to connect to the computer? Because a wireless mouse would have the mouse and a USB thing so it can send signals.
If your computer doesn't have Bluetooth built in, you can add it with a PCI card, card slot or USB adapter.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=100...dapter&x=0&y=0Recommends: Kiva.org - Loans that change lives.
you will have audio delay if you use bluetooth you will have to add a delay on your video player
CHEERS GARRY -
Thanks. Turns out the bluetooth device I looked at does have a USB thing, but it was not shown on the cover. Also how is bluetooth supported on a TV without built-in support? There is no USB port on the TV.
As edDV said, PC can add on a card or USB to add Bluetooth xmitter which send to BT receiver in speakers. TVs that don't already have BT xmitter built-in can NOT get an add on (maybe if has USB, but not likely).
Most of the "single earpiece" BT receivers are NOT meant for this usage, only "hands-free" usage. There are separate, more costly BT receivers that use 2 channels, not just 1. Those are the ones edDV and I are referring to.
newbie questions about ffmpegx
By Anoni in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 11:11 -
newbie x264fw questions
By anthell in forum Newbie / General discussionsReplies: 3Last Post: 10th May 2010, 05:33 -
Newbie Questions DVD to ????
By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 10:19 -
Some newbie questions about sirius
By janeydoll in forum AudioReplies: 9Last Post: 10th Jun 2008, 02:19 -
Newbie Mplayer questions
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 21st Dec 2007, 14:51
