hi
i have a panasonic hdc-hs9 recorder that records in .mts files witch i have never really used until now. usually i use my Sony that makes .vob files and use kino for editing and devede for authoring, well it isn't working with my .mts files,
#1 using kino to import my .mts files into .dv files it does it but the video is slow, like it is in slow motion the video is running slower than the audio.
#2 i tried using winff to convert the .mts files to .dv files below is what it gave me as an error:
FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1.2, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.1-1ubuntu1.2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
libpostproc 51. 2. 0 / 51. 2. 0
built on Sep 16 2011 17:08:44, gcc: 4.4.3
Input #0, mpegts, from '/media/11.10/00025.MTS':
Duration: 00:16:43.00, start: 0.344989, bitrate: 13194 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 59.94 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
Output #0, dv, to '/home/klein/00025.dv':
Stream #0.0: Video: dvvideo, yuv411p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 200 kb/s, 90k tbn, 29.97 tbc
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate=
0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbitframe= 0 fps= 0 q=0.0 size= 0kB time=10000000000.00 bitrate= 0.0kbit[dvvideo @ 0x1b04e70]Can't process DV frame #899. Insufficient audio data or severe sync problem.
frame= 911 fps= 10 q=0.0 Lsize= 105352kB time=30.02 bitrate=28752.7kbits/s
video:106758kB audio:5628kB global headers:0kB muxing overhead -6.259020%
FFplay version SVN-r0.5.1-4:0.5.1-1ubuntu1.2, Copyright (c) 2003-2009 Fabrice Bellard, et al.
#3 i tried to import the .mts files into Avidemux 2.5.2 it tells me the .mts file (This looks like mpeg
Do you want to index it?) and i click on ok , it starts indexing it then it tells me it has detected it to be a h.264 file if i tell it to use the unstable thing it completes when done i get a green screen in Avidemux if i try to play the movie the green goes to gray and i can hear the audio but i can't see the video, up in the left corner of the gray screen is a something maybe a very small distorted picture?
all i wont it to change my ,mts files to .dv so i can edit them in kino then convert them to mpeg for authoring can some on explain this to me or point me in the right direction?
post a small sample and maybe someone can find a solution.
manually copied of .MTS video files back to Panasonic HDC-90 memory card
By Rovi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Jan 2012, 13:17 -
Joined MTS files from Panasonic HDC-SD70, create audio delay...
By pleindepuces in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Dec 2010, 16:29 -
Panasonic HDC-SD60 .MTS help
By BookwormSkates in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Sep 2010, 11:21 -
Panasonic HDC-SD60
By jvidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 16th Jun 2010, 09:33 -
just got my first vidcam; a Panasonic HDC HS9 and after info on MPEG2 TS
By topcatstudios in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2009, 23:08
