I'm using TMPGEnc to encode video into VCD or SVCD format, and i'm not really sure about the INTERLACE / NON-INTERLACE settings.
In TMPGEnc, under SETTINGS, under the VIDEO tab, there are 3 choices for "Encoding Method":
1) When should I use INTERLACE for an encoding method?
2) When should I use NON-INTERLACE for an encoding method?
3) When should I use Inverse 3:2 Pulldown?
4) Why does NON-INTERLACE encoding take longer?
5) Which encoding method will produce a bigger file size?
6) Which encoding method should I use when making VCDs and SVCDs to play in my standalone DVD player?
In TMPGEnc, under SETTING, under the ADVANCED tab, there are 2 choices for video source type:
7) What kind of video sources are INTERLACED ?
8) What kind of video sources are NON-INTERLACED ?
I would appreciate any help. TMPGEnc help is not too good!
Thanks,
~Urbs~
You don't have to answer all the questions if you reply.
If you only know the answer to one of the questions, I would welcome that also!
Thanks again,~Urbs~ -
...just bumping it up.
c'mon....somebody's got to have an answer to at least one of these questions!
please....~Urbs~ -
WHEN YOU INTEND TO VIEW THE VIDEO ON TV
WHEN YOU INTEND TO VIEW THE VIDEO ON A COMPUTER MONITOR
WHEN YOU'RE TRANSCODING FROM NTSC(29.97FPS) TO FILM (24 FPS)
sOME PEOPLE BELIEVE YOU GET A MORE FILM LIKE VIDEO AT 24 FPS
NTSC IS NATIVE INTERLACED. IT HAS TO COMBINE 2 FIELDS INTO ONE FRAME.
DOESN'T MATTER
SVCD USES MPEG2. MPEG 2 RECOGNIZES BOTH INTERLACED AND NON INTERLACED. YOUR STANDALONE DVD PLAYER PLAYS ON TV, SO LEAVE IT INTERLACED(YOU'LL SEE MOTION ARTIFACTS ON THE COMPUTER MONITOR)
hOW DID YOU ACQUIRE? IF YOU USED A CONSUMER DV CAM, CAPTURE IN INTERLACED. iF YOU USED A tv SOURCE, LEAVE IT IN INTERLACED.
"FRAME MOVIE MODE" ON CANON XL1S AND SONY VX-2000 OR ANY OTHER "PROGRESSIVE" SOURCE
Check out this site:
http://www.geocities.com/lukesvideo/interlacing.html http://people.freenet.de/codecpage/MOBO: ASUS P4P800 Deluxe
CPU: 3 GHz P4
OS: Win 2k SP2
Audio: ECHO Mona
BSCVideo Card: ATi Radeon 9800 Pro
Video Capture: IEEE-1394 DV
HSF: Volcano 5
HDD: WD 1200JB
Video HD: WD1000BB
CD-RW: Sony
DVD-R: Pioneer A03
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 03:33 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
VirtualDub De-interlace
By Lee82 in forum EditingReplies: 16Last Post: 25th Feb 2008, 19:57 -
Interlace confusion
By Bagshot in forum Capturing and VCRReplies: 7Last Post: 16th Feb 2008, 09:46 -
Interlace or Progressive??
By Browncoat in forum Newbie / General discussionsReplies: 9Last Post: 31st Jan 2008, 16:14
