I recently purchased Black Magic Design's video recorder (consumer model) for around $150 from B&H. I was very disappointed with the quality of the video! At 3.5mbps the H.264 encoding quality of SD material was considerably worse than DV. I realize DV is 25mbps..but H.264 is a newer, much more efficient codec. I have had no problems getting good quality H.264 out of non-real time software such as an export from Apple's compressor or Final Cut Pro (I actually encode SD lower than 3.5mbps for high quality web video with very little noticeable loss in quality) using no additional hardware. The interface of Black Magic's software was also EXTREMLY desiappointing. I couldn't control the resolution, I could only use their pre-sets for iPod, Youtube, etc. Ironically, the iPhone (480x352) preset looked just as sharp if not better than their "full resolution" setting. Likely because 8mm video is interlaced and therefore in reality the "full resolution" setting at 640x480 was overkill and the lower resolution of the iPhone settings allowed for less macro blocking.
Anyway, my question is: Besides going out and spending $450=$500 on Black magic's h.264 pro recorder, is there anything else out there that is cheaper and/or better that I could use for capturing the 40 or so hours of 8mm video I have into h.264 files (preferably playable on iPad). I'm on the fence about purchasing this pro recorder-will probably sell it once I'm done if I do decide to buy it but I wanted to check here to see if there's a better option especially considering my experience with their other product.
I have a Macbook Pro 2.2ghz core 2 duo, 4gb ram running OS X lion currently, but it's having some issues so I'll likely be purchasing on of the i5 macbook pros w/thunderbolt soon. Also, I'll probably be purchasing a Digital 8 camera when I do this conversion as it seems one of with decent heads may provide better quality than the 15+ year old Samsung 8mm camcorder I have. Any input would be greatly appreciated!
Real time encode to h.264 is a hardware process. The quality depends on the BM hardware codec which seems to be less than optimal. A real time h.264 broadcast encoder runs $2K to $25K. To get the best out of it, cap to the higher bit rates and interlace at 640x480 (or 704x480) if possible. That will be your archive file. Then use that to re-encode for various devices. Most devices will require deinterlace before encode. I suggest Handbreak for encoding to mobile devices. It has a good deinterlace filter and uses the x.264 codec.
I prefer capping 8mm to DV, then encode non-realtime to MPeg2 or h.264.
I've found that my original 8mm camcorder to Canopus ADVC gets a cleaner capture than a D8 camcorder but mileage can vary.Last edited by edDV; 26th Dec 2011 at 14:44.
http://www.kiva.org/about -
I see, any thoughts on Black Magic's "pro recorder"? $500 seems pretty cheap in comparison?
EDIT: Also, after trying a friend's new macbook pro, it looks like it can encode h.264 close to 2x realtime but this isn't during capture. Is there some sort of software that could take an incoming video stream and convert this at the same time or do I have to just capture in say DV and then be encoding again in the background? Thanks for the bit on your camcorder being cleaner than a D8, I'll have to do a comparison.Last edited by salils; 26th Dec 2011 at 15:00.
Realtime encoding is a different process. With non-realtime software encoding, the encoder uses computer memory to see multiple frames at a time to do deinterlace or motion estimation. A good realtime encoder needs multiple frames of memory to do similar processing in hardware only. The cheap ones don't store frames so must resort to lower quality techniques. This means higher bit rates should be used to get acceptable quality.
All encoders-decoders that access frames of memory have delay. Mainconcept has a realtime software MPeg2 encoder that buffers video to memory for processing. It needed a Core2 Duo to do acceptable SD encoding. I'm expecting someone to do a software h.264 real-time encoder now we have i7 + ' Cuda GPU hardware assist.
Keep in mind that h.264 is intended to be asymmetrical (i.e. longer encode, faster decode).Recommends: Kiva.org - Loans that change lives.
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum Capturing and VCRReplies: 7Last Post: 4th Apr 2012, 23:36 -
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 02:15 -
Converting 8mm video to digital
By Victor Delta in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 17:27 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
Converting H.264 AVI files
By Alexstarfire in forum Video ConversionReplies: 2Last Post: 19th Sep 2007, 22:25
