  1. Hey,
    So I recently bought an Intensity Shuttle to record my PS3.
    But I can't seem to set it up correctly.
    I can set it up to reecord Composite with it but not Component.
    Can somebody give me a list of the settings or something like that?
    I live in Belgium if that's important.
    Thanks in advance!
  2. What resolution is your PS3 using when you connect it with a component cable to the Shuttle? Try this:
    - BlacMagic Design Control Panel -> set input to component
    - PS3 -> connect it to your TV with the component cable and make sure it's using a 720P or 1080i resolution, not 1080P.
    - Connect PS3 to Shuttle
    - Open Media Express -> Edit -> Preferences -> Video format: HD 720p 59.94 (or HD 1080i 59.94 depending on the resolution the PS3 is using)
    This should work.
