I have been using AVSTODVD to convert mutiple AVI files to a DVD format. The AVI files play correctly. The conversion completes successfully. However, in one of the converted Episodes the audio and video plays faster than normal. How can I correct this?
thanks in advance
thanks for the reply. Not sure what you are asking for and how to use mediainfo.
But here is the AVSTODVD log
BTW, the problem is with Episode 19
<12/25/2011 1:14:31 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 3
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: 5 Dae Jang Geum 17-19
DVD Menu: Motion Menu
Output Folder: F:\K Drama\Dae Jang Geum\Dae Jang Geum DVD
Delete Temp Process Files: Yes
Delete Working Files: No
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Arial 18pt Bold (255,255,0)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: MATSHITA DVD-RAM UJ862ES 1.90
DVD Burning Speed: 8x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 1
TITLE 1 SOURCE FILES
Video: F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E17.avi
Info: XviD - 1495 kbps - 576x432 - DAR 1.333 - 23.976 fps (CFR) - Progressive - 57:41 minutes - 82993 frames
Audio 1: F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E17.avi
Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 57:41 minutes (0 ms delay) - Internal
Subs 1: F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E17.srt
[MediaInfoLib - v0.7.50]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E17.avi", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=23.976, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E17.avi", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Lanczos4Resize(720,576)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 1340.5 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.HCenc.log
*MAXBITRATE 9000
*BITRATE 3248
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<12/25/2011 2:01:10 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: AVISource
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.m2v (1340.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3272 kbps - 720x576 - DAR 1.333 - 23.976 fps (CFR) - Progressive (TFF) - 57:38 minutes - 82910 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<12/25/2011 2:03:28 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.m2v (1340.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3269 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 57:41 minutes - 83076 frames
<12/25/2011 2:03:41 PM>
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E17.avi" -acodec copy "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_1.ToFix.ac3"
<12/25/2011 2:05:12 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_1.ac3 (79.2 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 57:41 minutes (0 ms delay)
<12/25/2011 2:05:13 PM>
START SUBS ENCODING OPERATIONS (Track 1)
SRT fixing routine applied (0 lines fixed)
SubtitleCreator Parameters: "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.srt" -p1 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<12/25/2011 2:05:28 PM>
END SUBS ENCODING OPERATIONS (Track 1)
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_1.sup (1.33 MB)
TITLE 2 SOURCE FILES
Video: F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E18.avi
Info: XviD - 1537 kbps - 576x432 - DAR 1.333 - 23.976 fps (CFR) - Progressive - 56:18 minutes - 81009 frames
Audio 1: F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E18.avi
Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 56:18 minutes (0 ms delay) - Internal
Subs 1: F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E18.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E18.avi", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E18.avi", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Target Video FileSize: 1308.3 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.HCenc.log
*MAXBITRATE 9000
*BITRATE 3248
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<12/25/2011 2:51:14 PM>
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.m2v (1308.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3272 kbps - 720x576 - DAR 1.333 - 23.976 fps (CFR) - Progressive (TFF) - 56:15 minutes - 80928 frames
DGPulldown Parameters: "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<12/25/2011 2:52:39 PM>
DGPulldown executed on File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.m2v (1308.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3269 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 56:18 minutes - 81089 frames
FFmpeg Parameters: -i "F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E18.avi" -acodec copy "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_1.ToFix.ac3"
<12/25/2011 2:54:09 PM>
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_1.ac3 (77.3 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 56:18 minutes (0 ms delay)
SRT fixing routine applied (1 lines fixed)
SubtitleCreator Parameters: "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.srt" -p1 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<12/25/2011 2:54:21 PM>
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_1.sup (1.3 MB)
TITLE 3 SOURCE FILES
Video: F:\K Drama\Dae Jang Geum\SSADae.Jang.Geum.E19..avi
Info: XviD - 918 kbps - 576x432 - DAR 1.333 - 23.976 fps (CFR) - Progressive - 59:43 minutes - 85917 frames
Audio 1: F:\K Drama\Dae Jang Geum\SSADae.Jang.Geum.E19..avi
Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 59:43 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("F:\K Drama\Dae Jang Geum\SSADae.Jang.Geum.E19..avi", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("F:\K Drama\Dae Jang Geum\SSADae.Jang.Geum.E19..avi", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Target Video FileSize: 1387.3 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19..HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19._1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19..m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19..HCenc.log
*MAXBITRATE 9000
*BITRATE 3248
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<12/25/2011 3:40:03 PM>
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19..m2v (1388.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3272 kbps - 720x576 - DAR 1.333 - 23.976 fps (CFR) - Progressive (TFF) - 59:39 minutes - 85831 frames
DGPulldown Parameters: "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19..m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<12/25/2011 3:41:13 PM>
DGPulldown executed on File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19..m2v (1388.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3269 kbps - 720x576 - DAR 1.333 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 59:43 minutes - 86003 frames
FFmpeg Parameters: -i "F:\K Drama\Dae Jang Geum\SSADae.Jang.Geum.E19..avi" -acodec copy "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19._1.ToFix.ac3"
<12/25/2011 3:52:05 PM>
Created File: C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19._1.ac3 (82 MB)
<12/25/2011 3:52:06 PM>
START DVD MENU BUILDING OPERATIONS
DVD Menu settings:
Style: 1
Aspect Ratio: 1
Titles Format: 1
Template: Menu in Black
Max Titles Page: 12
Enable Play All: 1
Force Play All: 0
Background Audio: 0
Max Thumbs Row: 4
Thumb Image Source: 0
Thumb Frame Position: 25%
HL Frame Format: 0
HL Selection Color: 5
HL Play Color: 0
Menu Video BitRate: 6000 kbps
Motion Menu Duration: 15 seconds
Thumb Drop Shadow: 2
Play All Shadow: 2
Arrows Shadow: 0
<12/25/2011 3:53:02 PM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_MenuPage1.m2v (10.7 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_BatchMux.ini"
BatchMux ini file:
-d "F:\K Drama\Dae Jang Geum\Dae Jang Geum DVD\5 Dae Jang Geum 17-19_0\VIDEO_TS"
-mxp "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_MuxMan.mxp"
-l "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_Palette.txt"
-v "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17.m2v"
-vidmode 4:3
-a1 "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_1.ac3"
-a1lang en
-s1 "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_1.sup"
-s1lang en
-s1ext 1
-cellfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_Chapters.txt"
-progfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_Chapters.txt"
-chapfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_01_Dae.Jang.Geum.E17_Chapters.txt"
-SEG2v "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18.m2v"
-SEG2vidmode 4:3
-SEG2a1 "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_1.ac3"
-SEG2a1lang en
-SEG2s1 "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_1.sup"
-SEG2s1lang en
-SEG2s1ext 1
-SEG2cellfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_Chapters.txt"
-SEG2progfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_Chapters.txt"
-SEG2chapfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_02_Dae.Jang.Geum.E18_Chapters.txt"
-SEG3v "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19..m2v"
-SEG3vidmode 4:3
-SEG3a1 "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19._1.ac3"
-SEG3a1lang en
-SEG3cellfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19._Chapters.txt"
-SEG3progfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19._Chapters.txt"
-SEG3chapfr "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Title_03_SSADae.Jang.Geum.E19._Chapters.txt"
-SEG4v "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_MenuPage1.m2v"
-SEG4vidmode LB
-SEG4s1 "C:\Users\Steve\Videos\5 Dae Jang Geum 17-19_0_Menu.sst"
-SEG4s1dmode WIDE_LB
-SEG4hlmnu "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_MenuPage1_Buttons.mnu"
-SEG4hlcsm "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_HighlightScheme.csm
-hcn "C:\Users\Steve\AppData\Local\Temp\5 Dae Jang Geum 17-19_0_BatchMux.hcn"
<12/25/2011 3:59:04 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 4402.3 MB
vs Estimated Size: 4450 MB -> 1.1% undersize
vs Assets Size: 4289.7 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: F:\K Drama\Dae Jang Geum\Dae Jang Geum DVD\5 Dae Jang Geum 17-19_0 (4402.3 MB)
<12/25/2011 3:59:05 PM>
Log file created by AVStoDVD Release 2.4.2
<>Last edited by stem300; 26th Dec 2011 at 05:01.
Info from Media info Tho not sure how to read.
many thanks -
I think the question here is, were the problem episodes produced the same way, with the same codecs, as the good ones?
Some these video files are of, ahem, dubious provenance. They may have been ripped on a system that has codecs installed that you shouldn't install on a Windows system. The support section on the Microsoft site specifically says you shouldn't install any 3rd party codec packs on a Windows 7 system. I stick to software that uses directshow or directx or the .NET framework.
AVStoDVD has taken almost everything I've tossed at it. I've had a few files that wouldn't work ... Avisynth couldn't frameserve them ... but I've been able to use them by using Avidemux to convert them and use that as input. Avidemux isn't the easiest program to use but it's a great editor/converter and will deal with files that Avisynth can't.
Plus some rips were done with software that isn't that great. It has no 2 pass mode or it wasn't used. 2 Pass is really the only way to get best quality and more reliable sync.
What I'd try first is, check Settings and if the program didn't auto select 2 pass VBR mode select it. Then try again.
However, some rips just aren't good. Try playing the problem source avi's with VLC. If that doesn't give you good quality I don't think anything will.
I almost always burn my AVStoDVD output to DVD-RW first to make sure it's good. Best way to minimize coaster production. -
Thanks for the reply. Couldn't keep stay awake.
AVI files are attached.
Ep 18 converts ok.
Ep 19 is the problem file. Ep 19 also plays perfectly with VLC.
I was able to convert EP 19 as a single conversion. I hard subbed it first before the conversion as an experiment. But it doesn't work if I add multiple files.
thanks again
AVStoDVD Audio sync (m2ts source)
By newbtube in forum Video ConversionReplies: 10Last Post: 5th May 2011, 22:57 -
AVStoDVD audio out of sync from TS source
By nazopo in forum DVD RippingReplies: 3Last Post: 20th Dec 2010, 22:02 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 01:29
