OK... 1) If you are going to capture any toons, you must apply temporal, noise and spacial filters to get solid colors (mpeg compression is grateful of solid colors and no random floating points)
2) In the case that you canīt capture directly in Virtuadub (w/huff 352x480 recomended and then deinterlace and resize to 352x240) because you are at work, my alternative is capture in mpg high bitrate to keep details and donīt get a big file (30 min +/- 2.2 gig), so I can save up to 7 chapters and then process each one to avi, apply filters, and reencode to VCD mpg.
3) Now Iīm trying to capture directly in virtualdub w/vd_start posted few days ago, and then using a program that sends keystrokes to windows opened, I managed to frameserv to TMPenc so in the next morning I get a vcd mpg ready to cut commercials, and a bath file that deletes the avi file created during capture. HD ready to capture at 20:00 again. (the whole thing is minimun intervention!)
On 2001-06-30 20:29:18, patrickm wrote:
not that there's anything wrong with your program, for him i just don't think it's the best solution.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
patrickm:
I was just responding to what he said -- "The VCD quality of AIW is awful." -- I wanted to point out that the AIW default setting for VCD is poor but it doesnt have to be
I also agree it probably isn't the solution for what he wants as a final result
tempepo:
you might want to look into capturing with VirtualDub and a lossless codec to AVI then converting it to MPEG-1 or MPEG-2 ... thats probably your best bet for quality
A Great Editing Example
By budwzr in forum EditingReplies: 0Last Post: 22nd Jul 2011, 17:26 -
What would be a great room size for great video production?
By williec in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2011, 04:43 -
It seems like a great deal!
By blackrice in forum Off topicReplies: 5Last Post: 3rd Mar 2011, 09:53 -
Want to capture old, not great quality VHS without losing too much..
By Corbeau in forum Capturing and VCRReplies: 8Last Post: 16th Sep 2009, 06:32 -
Great feedback...now new PC!
By 123fish123 in forum ComputerReplies: 26Last Post: 29th May 2007, 18:59
