Hi all,
I need help with converting avi to dvd-playable video and burning it with burn for Mac. I use ffmpegx to convert the avi-file, and when I add it to my Burn directory for burning it, it burns nothing on my disc. What do I do wrong?
The details for my processing this issue is this:
I start ffmpegx, then add my avi-file to the program. I select DVD mpeg2enc as target format. Then I click encode.
The result is a video-ts folder, which I then add to my Burn-program. I choose DVD-Video as output format, and click "burn". A dialogue box comes up, which says "Checking" for a few minutes, and then it is done. The result is a disc with nothing at all on it.
Do I do something wrong?
UPDATE: When I add files that I know are already in .mpg format to Burn, a dialogue box comes up that says "One incompatible file. Would you like to convert that file to mpg?" Is there something wrong with my Burn program?
The Help files for Burn-OSX says one should select the output format before adding files, so there may be an issue in the order that you did things?
Another thing to check is the content of the VIDEO_TS folder. If everything was authored as it should, then the contents of the folder should look something like:VIDEO_TS.BUP
There may be more files, but it should contain at least these files.
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_1.VOB
Originally Posted by allakantralla
Perhaps that .mpg file is indeed not compatible with the DVD standard. Frame size could be off, frame rate could be off, bitrate could be too high, pulldown flag could be missing. Hard to say without looking at the details of this file.Originally Posted by allakantralla
m2ts to burn in Toast 11 (MAC) Issue
By Reesche in forum MacReplies: 3Last Post: 27th Sep 2011, 14:55 -
Unable to burn a DVD (Mac)
By kayar in forum Authoring (DVD)Replies: 4Last Post: 9th Jan 2010, 13:36 -
How to Burn an ISO on the Mac
By Jeff_NJ in forum MacReplies: 6Last Post: 19th Nov 2008, 09:11 -
Capture PC burn for mac
By TripScott in forum Video ConversionReplies: 2Last Post: 5th Nov 2007, 14:34 -
How to burn a ISO file on a Mac? Can this be done?
By babybreese in forum MacReplies: 9Last Post: 30th Aug 2007, 20:45
