What is the best video format, if need be compress good or has the best HQ if no compression is needed ?
- Quicktime
- AVI
- MPEG-2 I-Frame SD and HD
Results 1 to 11 of 11
Quicktime and AVI are containers not codecs.
"Best video format" depends on your intended use. Explain how this file will be used and the types of source files that you want to re-compress. Any re-compression will lower quality.
The most generic "high compress" codecs are h.264 with AAC or AC3 audio in an mp4 container.
If it needs to play on an old DVD player, you are forced into MPeg2/AC3 or if supported SD dvix/xvid.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
There may be times I need to write 720p video to a codec from 32-bit TIFFS or EXR files (sometimes, targas). From their I may compress it further which I would go with h.264. I want a codec that will keep the quality has high as possible. I know I can write AVI uncompressed with doesn't do any compression, but AVI seems to lack even at uncompressed something that I can't put my finger on it, maybe it's nothing and I'm over reacting but maybe there is ?
Uncompressed AVI will be large and mostly unplayable without RAID. What is your frame rate?
If the source is progressive, then h.264 is typical for 720p source. For interlace source it gets more complicated.Recommends: Kiva.org - Loans that change lives.
24 or 29.97 fps.Uncompressed AVI will be large and mostly unplayable without RAID. What is your frame rate?
Uncompressed AVI will output bit-for-bit what went in. You can also use lossless codecs like HuffYUV or Lagarith or MSU Lossless Be aware of colorspace. If your source is RGB you want to compress it as RGB (assuming you want perfect output), not YUY2 or YV12, or some other subsampled chroma YUV format. Make sure the compression software or codec isn't converting to YUV. And lossless codecs usually don't give you a lot of compression. Real world video gets reduced to about 1/2 to 1/3 the uncompressed size. Cartoons and Anime can get much more compression because of the low amount of detail.
Strictly speaking about AVI input/output from what I read Lagarith is the best codec for the job as HuffYUV has some flaws. As you mentioned HuffYUV is probably best for cartoons. Are those two options your personal recommendation ? You are excluding out QT and MPEG-2 any reason for that ? I know QT can have issues.
I second Huffyuv for RGB still frame source. That converts it to playable video with no loss.
Later you will load this into an editor or encode directly to distribution formats. That is when you convert to MPeg2 (for DVD or BluRay) or h.264/AAC for Youtube or whatever your distribution goal.Recommends: Kiva.org - Loans that change lives.
Convert .exe video tutorials(built by Screencam) to video format
By cyforex in forum Video ConversionReplies: 3Last Post: 1st Apr 2012, 17:11 -
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 17:52 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
VIDEO-TS.......how do i change format from disc to my video files
By COT51E in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2008, 12:32 -
How to convert video format of a video made on iMovie on a mac?
By squeejiboo in forum MacReplies: 1Last Post: 30th Jun 2008, 07:47
