  1. Is there an alternative to AVC2AVI which supports Audio files too?
    I mean, a software to do the same as this one, but with another box to select an Audio file, resulting in a single full movie (audio and video)
    I'm trying to... "merge" a .264 Video (not .H264) with a AAC Audio File. They both from a FLV File (splitted with FLVExtract).
    Merry Christmas.
    URGENT is everything someone INCOMPETENT did not ON TIME and want you KILL yourself to do in RECORD time.
  2. DECEASED
    Jun 2009
    Heaven
    No, there isn't.
    SFAIK, only AVI-Mux GUI can mux AAC in AVI safely, but it doesn't accept "container-less" AVC streams.
    Also, if the source is an FLV file, probably the video has VFR, which is not supported by the AVI container.
  3. Sorry, I don't understand these video-related terms too much yet. What is a container-less AVC Stream?
    And about VFR, if you mean Variable Frame Rate, I think so.
    Maybe the best free approach is mux this 264 File to AVI and add the audio with VirtualDub. To bad it doesn't accept AAC format, so I have to convert it and pray to not get async.
