Results 1 to 13 of 13
  1. I need to burn a CUE file for a vcd but the 2 programs i have tried are for some reason not working:
    CDRWIN and Fireburner
    Know of any others that i can download?
    THANKS
  2. If you want to burn DVD2SVCD .cue files use NERO
    If Iīm wrong and you donīt want to burn DVD2SVCD .cue files then...use NERO 8)
    Jul 2001
    One Step From Hell
    THANKS
    When you say 'not working' what do you mean????? Do you get an error? Also with my experence NERO is the last program you want to use to burn bin/cue.
  4. @ newcs: thas cold man! nero is one of the best out there. just get daemon tools and nero is as good as it gets when burning .cue/.bin.
    @questi: theres a bunch of progs that you can use. as i said earlier you can get daemon tools and then use nero to burn the files. or you can use fantomcd to burn the .cue or .bin. these two are probly the best. cdrwin works too. theres a bunch of more but i cant remember.
    Jul 2001
    One Step From Hell
    I used to think the same thing till I started using VCDImager and CDRWin.
    Heres an example:
    My brother d/l'ed that Steve-o video. UN-Rared it and burned the mpg with NERO as SVCD. Put it in my Apex500w and TRIED to play it, was all blocky, sound was lame sounding.
    Then I used vcdimager to make a bin/cue and burned it with CDRWin. PERFECT.
    Do a side by side and you be the judge.
  6. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Yeah, I've had Nero F up a bunch of bin burns. Use CDRWin by all costs OR
    Use IsoBuster to extract the contents from the Bin/Cue then re-author in Nero
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  7. What's the difference of making a (s)vcd straight from MPG using Nero instead of making an image of it?
    Does it makes it smaller filesize? Better quality? or what is it?
    Peace Love and Technology!
    Iverson#3
  8. To burn Images .cue .bin I use Nero but with a twist. I have installed on my system daemon tools 3.02 (http://www.daemon-tools.net/main800.htm) and the drive image fron nero Too.
    I load the .Cue with Daemon tool and in Nero I do a CD to CD copy. Never had any trouble.
    That way I can try the image first with PowerDVD.
  9. Nero is the best but there's one problem. Power dvd has a trouble reading the disc. Windvd seems to work though. I've also read in sefy's guide that discs burned by nero won't work on dvd players. Can anyone here confirm their findings?????
    Aug 2001
    Hull
    I use Blindwrite suite to burn my cue/bin files. I have had no problems with cue/bin files that VCDEasy makes or DVD2SVCD makes.
    8)
  11. all my svcd's and my dvd-r images that I burned in Nero work fine. The DVD-R images are pre-authored in Spruce Up or DVD Movie Factory. My SVCD mpegs are rendered in Video Vegas. My DVD Homeplayer is a Pioneer and 2 Sonys, only the Pioneer plays back SVCD and other formats, the Sonys just play back DVD-R/-RW and VCD.
  12. Nero is by far one of the best burning programs out there and gives alot of control, however, like most programs, it does have bugs in it, and old builds had a problem that if you burned a Cue/Bin file through it, the movie would not play on the DVD.
    Newer build however have been reported to burn Cue/Bin files correctly and without problems, although I still prefer using programs that are specific to this format, it does not mean Nero cannot burn, but once you get burned...
    These programs can handle Cue/Bin correctly:
    BlindWrite Suite
    GoldenHawk CDRWin
    FireBurner
    CDRDao + GUI
    Nero Burning-ROM (recommanded 5.57x builds)
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  13. I cant receive WB programing here so I download the episode from alt.binaries.smallville
    After I uncompress the epsisode I allways test the image opening the .cue/.bin with Daemon tools and then trying it with PowerDVD, sometimes PowerDVD say Unsoported format so I go directly to the folder were the movies at and play with no problem.
    I have burn this image before and it played OK in My Daewoo 3000 but on PowerDVD no.
    What I am doing right now is extracting the movie with TMPGenc (Load the .cue/.bin with Daemon Tools and in TMPGenc I go to File=>MPEG Tools=>Merge and cut, and select the .dat or .MPG and save it to the Hard Drive, I make a new .cue/.bin with VCDEASY and try it again with Daemon Tools and no problems with PowerDVD and The DVD player)
    On Nero I Select Copy CD to CD making the Source CD the Virtual CD DRIVE from Daemon Tools
