  1. A strange question. For xmas, I've gotten my wife a blu-ray player and a bunch of discs I know she wants. The player is a Panasonic, and has a usb jack in front as it also plays .mkv files. Tried out 3 mkvs (not created by me); one plays beautifully, but the other 2 prompt the message "cannot play protected DIVX content". DIVX?? All of these files are mkvs, and all play great in my little Micca media player. But the blu-ray player is reading two of them as "protected Divx". So I'm wondering if any experts out there have a clue what would make an mkv read as a divx, and why it would be protected. Thanks.
    Nope.
    Post the full details from the mkvs that doesn't work. Use MediaInfo.
  3. Thanks, I'll download mediainfo and get on it.
  4. Here are the facts on one of the files as reported by mediainfo. All I've removed is the filename:
    General
    Unique ID : 253489480681380152731021653959976376199 (0xBEB44C531BECE8EBAFA45186BDEB5787)
    Complete name : F:\XXXXXXX [1080p].mkv
    Format : Matroska
    Format version : Version 2
    File size : 7.95 GiB
    Duration : 1h 38mn
    Overall bit rate : 11.6 Mbps
    Encoded date : UTC 2010-02-03 10:15:53
    Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 38mn
    Bit rate : 8 533 Kbps
    Width : 1 920 pixels
    Height : 824 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.225
    Stream size : 5.71 GiB (72%)
    Writing library : x264 core 83 r1400 20fa784
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8533 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : No
    Forced : No
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Duration : 1h 38mn
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1.04 GiB (13%)
    Language : English
    Default : Yes
    Forced : No
    Audio #2
    Format : DTS
    Codec ID : A_DTS
    Duration : 1h 38mn
    Bit depth : 24 bits
    Language : Italian
    Default : No
    Forced : No
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Language : English
    Default : No
    Forced : No
    Menu
    00:00:00.000 : en:00:00:00.000
    00:05:40.090 : en:00:05:40.090
    00:07:50.679 : en:00:07:50.679
    00:14:12.518 : en:00:14:12.518
    00:18:55.718 : en:00:18:55.718
    00:24:23.379 : en:00:24:23.379
    00:29:56.128 : en:00:29:56.128
    00:34:15.095 : en:00:34:15.095
    00:39:23.987 : en:00:39:23.987
    00:42:54.155 : en:00:42:54.155
    00:46:47.763 : en:00:46:47.763
    00:50:14.762 : en:00:50:14.762
    00:55:46.134 : en:00:55:46.134
    00:59:46.291 : en:00:59:46.291
    01:08:45.913 : en:01:08:45.913
    01:16:28.584 : en:01:16:28.584
    01:20:26.947 : en:01:20:26.947
    01:27:19.860 : en:01:27:19.860
    01:31:57.178 : en:01:31:57.178
    01:37:07.488 : en:01:37:07.488
    01:38:17.308 : en:01:38:17.308
