Hi all,
can someone suggest a good usb capture card ?
I have found EzCap (formerly Easycap, but it seems full of fake products) and EZGrabber2 from another manufacturer, that seems better supported (you can download drivers from an official page)
Any suggestions based on real life experience are welcomed.
Thank You !
This place sells the REAL EZcap.....and only here:
http://www.ezcap.tv/
I don't own one but often thought about getting one to test it. -
The KWorld DVD Maker USB 2.0 VS- USB2800 gets a lot of good reviews http://www.newegg.com/Product/Product.aspx?Item=N82E16815100112 It is probably a bit better than the EZGrabber2. The EzCAP model hech54 suggested is better than the cheap Easy Cap knock-offs sold on many websites. I don't own any of them, so I can't comment on the quality of their analog to digital conversion.
I have used internal versions of the the ATI TV Wonder™ HD 650. It does an excellent job of converting analog to digital. It has some quirks that make it a less than perfect choice for digitizing VHS or other analog tapes, unless you add some additional equipment between the tape player and the capture device. It seems fine for capturing the output from a cable box or ATSC converter box.
Need Sugestions for Camcorder with mic input under $300
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Apr 2012, 21:07 -
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 03:03 -
Usb Capture Cards and Software Motion Detection
By glvid in forum Capturing and VCRReplies: 2Last Post: 6th Jan 2012, 09:44 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
How can I use multiple usb video capture cards on one computer?
By gbenson in forum Capturing and VCRReplies: 0Last Post: 27th Jan 2011, 20:47
