Results 1 to 9 of 9
  1. Hi, I would like to know how to extract a ISO image file to PC without the need of burning to disc? please advice.
    thanks.
    May 2009
    Mexico
    Use IsoBuster.
  3. Member p_l's Avatar
    Montreal, Canada
    Mount it with Virtual Clone Drive or some other virtual drive app.
    Edit: or use ISOBuster ( thanks, luigimar). What do you want to do with your ISO, explore it and so on, or extract unreadable data or video files? Or do you mean "extract" (copy) a disc to your computer in ISO format?
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    WinRAR will do it also
  5. Mod Neophyte redwudz's Avatar
    USA
    I've found ISOBuster the best choice for my extractions. I use it on iso, .bin/cue, .nrg and other containers. Also for extracting MPEG files from KVCDs or SVCDs. And for extracting VIDEO_TS folders from image containers. It's very fast and easy to use.
  6. Member blinky88's Avatar
    Mar 2004
    Australia
    I have been using DVDShrink (FREE) for years never had a problem, quick and easy.
    Cheers from downunder.
  7. Member classfour's Avatar
    The Heartland, United States
    DVDfab has a free virtual drive
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    DVD Shrink with no compression or i use Winrar A LOT!!!!!!
    Winrar several times a week and i have never had an issue.
    Sep 2018
    Berlin
    WizISO (https://www.iseepassword.com/iso-editor.html ) can do that for you , extracting iSO file is not an easy task .
