Hi, everybody
I've been using this forum for a long time but only now decided to join in... So this is my first post.
I'm a linux user and while searching for a xml chapter file maker for matroska video format, discovered that most available and viable options are Windows related so I've been playing with bash and develop my first bash script, not counting the 'Hello World' one.
For those how don't know the ropes already copy paste the code bellow in a new file on you favorite text editor and save it, mark the file as executable and you're ready to go. The script has a built-in help, so use it if needed.
Here goes,
Hope you'll use it and tell me what you thing of it.Code:#!/bin/bash ## ## XML chapter file creator for matroska video format ## ## Version History ## 0.5 * basic file structure creation ## ## 1.0 * added more command line options and help ## * usage of random numbers for UIDs ## * usage of mediainfo for video length ## ## 1.1 * added floating number calculation for chapter size accuracy ## unfortunately this delays the program ## * add support for filenames with spaces ## version="XML chapter file creator for matroska video format mkchapters version 1.1 created by perdigueiro " usage=" Usage: $0 [OPTIONS] SRCFILE [DSTFILE] Examples 1st: $0 SRCFILE 2nd: $0 SRCFILE DSTFILE 3rd: $0 [-c | --chapters=NUMBER] [-t | --length=TIME] DSTFILE In the 1st form, create xml file with same name as source file with 15 chapters. In the 2nd, same as in the first form but use the specified destination file In the 3rd, create destination file with the specified time length Options: SRCFILE source file DSTFILE destination file, if not used assume source file with XML extension -h, --help display this help and exit. -v, --version display version info and exit. -c, --chapters=NUMBER number of chapters to create default is 18 -t, --length=TIME Video length in format HH:MM:SS or number of seconds, is ignored, if given a source file --prefix=WORD Chapter name prefix, default is 'Chapter' --lang=WORD Chapter language, default is 'eng' " ch=18 prx="Chapter " lang="eng" while test $# -ne 0; do case $1 in --help|-h) echo "$version$usage"; exit 0;; --version|-v) echo "$version"; exit 0;; --chapters=*) ch=${1#*=}; shift;; --length=*) ch=${1#*=}; shift;; --prefix=*) prx=${1#*=}; shift;; --lang=*) lang=${1#*=}; shift;; -c) ch=$2; shift 2;; -t) length=$2; shift 2;; -*) echo "$0: invalid option: $1" >&2; exit 2;; *) break;; esac done if [[ $# -ne 0 && -z $in ]]; then in=$1 shift while [[ $# -ne 0 && `expr match ${in:${#in}-1} '\'` -ne 0 ]]; do in="$in $1" shift done fi if test $# -ne 0; then out=$1 shift while [[ $# -ne 0 && `expr match ${out:${#out}-1} '\'` -ne 0 ]]; do out="$out $1" shift done elif [[ -n $length ]]; then out=$in unset -v in else out="${in%.*}.xml" fi if test $# -ne 0; then echo -e "$0: Too much arguments.\n" >&2 exit 2 fi if [[ -n $in ]]; then echo -e "\nUsing $in as input file" info=$(mediainfo $in | grep -m 1 "Duration") time=$((`expr match "$info" '.*\([0-9]\+\)h'`*60*60 + `expr match "$info" '.*\([0-9][0-9]\)mn'`*60)) elif [[ `expr match "$length" '[0-1][0-9]:[0-5][0-9]:[0-5][0-9]$'` -eq 0 && `expr match "$length" '[1-9][0-9]\+$'` -eq 0 ]]; then echo -e "$0: Invalid time format, must use HH:MM:SS or number of seconds.\n" >&2 exit 1 else if [[ `expr match "$length" '[1-9][0-9]\+$'` -ne 0 ]]; then time=$((length*1)) else time=$((${length:0:2}*3600 + ${length:3:2}*60 + ${length:6:2})) fi fi if [[ -n $out ]]; then echo -e "\nUsing $out as destination file"; fi echo -e "Total movie length is $time seconds\n" echo -e "\nCreating $ch chapters with $(($time/$ch)) seconds each." if [[ -f $out ]]; then read -p "File exists, do you want to overwrite? [Y/n] " -n1 -s answer if [[ $answer -ne "n" || $answer -ne "N" ]]; then echo "N" echo -e "$0: Aborted by user.\n" >&2 exit 0 else echo -n "Y" fi fi echo # Create list of Unique ID's UIDs=($(od -N$(($ch*4+4)) -An -t u4 /dev/random)) #Create Chapter Atoms function getAtom(){ local st=$(printf "%02d:%02d:%06.3f" ${starttime[0]} ${starttime[3]} ${starttime[4]}) local en=$(printf "%02d:%02d:%06.3f" ${endtime[0]} ${endtime[1]} ${endtime[2]}) printf "%03d> %s %s\n" $1 $st $en atom="\n\t\t<ChapterAtom>" atom="$atom\n\t\t\t<ChapterDisplay>" atom="$atom\n\t\t\t\t`printf "<ChapterString>%s %02d</ChapterString>" $prx $1`" atom="$atom\n\t\t\t\t<ChapterLanguage>$lang</ChapterLanguage>" atom="$atom\n\t\t\t</ChapterDisplay>" atom="$atom\n\t\t\t<ChapterUID>${UIDs[$1]}</ChapterUID>" atom="$atom\n\t\t\t<ChapterTimeStart>$st</ChapterTimeStart>" atom="$atom\n\t\t\t<ChapterTimeEnd>$en</ChapterTimeEnd>" atom="$atom\n\t\t\t<ChapterFlagHidden>0</ChapterFlagHidden>" atom="$atom\n\t\t\t<ChapterFlagEnabled>1</ChapterFlagEnabled>" atom="$atom\n\t\t</ChapterAtom>" return 0 } #Create XML structure function getXML(){ local xmlh="<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n\n" xmlh="$xmlh<!-- <!DOCTYPE Tags SYSTEM \"matroskatags.dtd\"> -->\n\n" xmlh="$xmlh<Chapters>\n\t<EditionEntry>\n\t\t<EditionFlagHidden>0</EditionFlagHidden>\n" xmlh="$xmlh\t\t<EditionFlagDefault>0</EditionFlagDefault>\n" xmlh="$xmlh\t\t<EditionUID>${UIDs[0]}</EditionUID>" local xmlb="\n\t</EditionEntry>\n</Chapters>\n" starttime=(0 0 0 0 0) #Start time for (( i=1; i<=$ch; i++ )); do endtime=($(bc -q << CALC if($ch==$i) { tm=$time } else { scale=3 st=$time/$ch tm=st*$i } scale=0 h=tm/3600 m=tm%3600/60 s=tm%60 m1=(tm+0.1)%3600/60 s1=(tm+0.1)%60 print h," ",m," ",s," ",m1," ",s1; quit CALC )) # Calculate endtime getAtom $i starttime=(${endtime[@]}) #Set start time atoms=$atoms$atom #Add Chapter Atom done xml="$xmlh $atoms $xmlb" return } getXML echo -e $xml > "$out" echo -e "\nDone" exit 0
Hi perdigueiro,
I followed your directions above and when I tried to run your script I got the following error messages:
./MKVXMLchapterCreator: 91: [[: not found
./MKVXMLchapterCreator: 105: [[: not found
./MKVXMLchapterCreator: 125: [[: not found
./MKVXMLchapterCreator: 125: Bad substitution
I was wondering if you could help me troubleshoot this error (only if you have some free time) since I am not much of a programmer but am willing to learn. I am planning to start learning Linux shell scripting this week.
BR,
drajc07 -
Hello drajc07,
I'm afraid your system is using sh by default and my script is bash as declared in the shebang.
Probably the location of your bash interpreter is other than /bin/bash, find it and change the shebang accordingly. -
just for the record: Hybrid can create mkv/mp4/m2ts chapters for quite some time,... (and it works on Windows/Mac/Linux) it allows you to create chapters every X min, import chapters from a source, edit existing chapters and export the chapters as mkv chapter file in the case that you don't want to use Hybrid for encoding,..
Create chapter file for MKV video
By RogerTango in forum Video ConversionReplies: 22Last Post: 16th Feb 2016, 04:02 -
Mkv xml chapters to mp4
By Sem in forum Newbie / General discussionsReplies: 0Last Post: 2nd Apr 2011, 19:31 -
mkv chapter file problem
By Bully9 in forum EditingReplies: 12Last Post: 22nd Mar 2010, 19:06 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 12:03 -
Xml tags when adding srt subs to mkv with mkvmerge gui?
By branch in forum SubtitleReplies: 0Last Post: 15th Mar 2010, 00:11
