Hi everyone,
I have a 32" Sony Bravia HD flat screen TV that is less then a year old that has been working great. It's connected to a DISH Network HD satellite receiver with a HDMI cable.
Yesterday I bought a Vizio VBR122 Blu-Ray player, connected it with a new HDMI cable with no problem, watched a movie, then after switching back to view TV the screen was a fuzzy pink. For a few seconds the screen would go black then back to fuzzy pink, then the TV would be OK for a while. So I disconnected the HDMI cable and the TV worked fine.
What could be causing this and is there any solution that isn't going to cost me more money?
Any help be greatly appreciated!
Thank you!
Sure, I've seen that on my HDTV.
Go into the video settings of your Blu-Ray player. You probably have a listing for YCbCr (HDMI). Your choices will be:
Auto
YCbCr (4:2:2)
YCbCr (4:4:4)
RGB (16-235)
RGB (0-255)
You're probably set on auto. Try another color setting to match your inputs. Your TV doesn't like going from one colorspace to another.
Good luck.
[EDIT] And welcome to the forum.Last edited by fritzi93; 23rd Dec 2011 at 10:44.
Pull! Bang! Darn! -
If the changing the colorspace doesn't help then also turn off 3D and anything else your TV doesn't support. Go to the manufacturers website and look for a firmware update, also go to Sony's website to see if there's an update for your TV. A bad cable or HDMI port can also cause this problem but you usually get a green screen.
Also try switching the hdmi cable to the port you know is working properly. If this is your first time using the second port it possibly might have problems you never knew if you only used the first one.
Hopefully that isn't the case as that would be a lot more serious problem but might as well eliminate all possibilities.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Blu-Ray Turns off when playing MKV file
By Bobor in forum Newbie / General discussionsReplies: 9Last Post: 4th Mar 2012, 07:42 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
Copyed Blu ray won't play in blu ray player
By gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 15:58 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48
