I'd appreciate some honest feedback for this intro. I'm getting ready to launch a tutorial series on advanced Vegas concepts, and I'll probably use the same intro for all of them.
I know intros are annoying, but they help branding, and I have a lot of competitors. My tutes will all be advanced topics. Mostly I'd like to know what kind of sense of feeling does it impart.
There's no voiceover yet, so after the intro you can click off.
Thanks in advance.
				Results 1 to 12 of 12
	That's because the "secrets" are hiding in it, so it's hard to see them, they're in the shadows, get it? So it doesn't work? OK, thanks.
 The "shakers" in the music are supposed to be the sounds of the shaman (me) chasing away the locks. Did you get that part at least?
 Hahaha, I'm kidding man, LMFAOROTF
	The loops are from "Nu Disco" collection, good ear. Hahaha. The "bloom" sound in the beginning represents all the little guyas flourishing and showering down from heaven. Did you get THAT part? Hahahaha.
 So the subliminal message is: "Guyas are good, locked secrets are bad, so if you stick with Guya, you're in, no more locks".
	All well and good but I could not figure out why you are a vacuum cleaner fanatic.
	You might try a larger mouse pointer. It would be easier to see and follow on a small screen. I use the 'extra large black' on my laptop and it helps.
  Bug in VirtualDub (?) -- can't cut desired number of framesBy ralf07 in forum Video ConversionReplies: 3Last Post: 21st Sep 2011, 18:50
  XMedia Recode: Can You Set the Desired File Size?By jdanniel in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 19:07
  Converting DVD Movies to the iPod WITH Desired SubtitlesBy jsegovia in forum Video ConversionReplies: 1Last Post: 18th Jan 2010, 09:01
  VirtualDub: "The audio codec cannot compress the source to the desiredBy user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 20:35
  Super Simple Free VOB to DVD program desiredBy nerys in forum Authoring (DVD)Replies: 3Last Post: 2nd Sep 2007, 17:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
