Computer Specs:
Time of this report: 12/22/2011, 13:39:34
Machine name: NEONESS
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HPE-560Z
BIOS: BIOS Date: 09/07/10 09:56:31 Ver: 6.09
Processor: AMD Phenom(tm) II X6 1045T Processor (6 CPUs), ~2.7GHz
Memory: 8192MB RAM
Available OS Memory: 8184MB RAM
Page File: 2437MB used, 13928MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Let me start from the beginning...
Yesterday I had gotten off work and was going to play the new Star Wars: The Old Republic game. But, I noticed that I had a Windows Update notification at the bottom right of my screen, so I clicked it and it told me I had 1 required update, and 3 optional updates.
The main update was:
- Update for Microsoft XML Core Services 4.0 Service Pack 3 for x64-based Systems (KB973685)
The optional updates were:
-Samsung - Display - SyncMaster P2770H/P2770FH (Digital)
-Advanced Micro Devices, Inc. - Display, Other hardware - AMD Radeon HD6570
-Update for Windows 7 for x64-based Systems (KB2607576)
So my thoughts are: "Okay, I can update windows and get these others, I have time." So I start to install the updates.
After my computer resets, and tells me that the updates were successful, I felt that I wanted to watch the new video on Thatguywiththeglasses.com.
But, instead of getting a good picture, I got this:
(The right is what it should be, the left is what it was.) It was really blurry, and the colors are somewhat blended onto each other. I've been calling it a 'Cell-Shaded' effect.
I tried other videos; I even tried videos on my computer, but they all have this weird effect.
My Star Wars game runs fine still, so it has to be something with my video (both Media Player Classic, and Adobe Flash Player).
So, I uninstalled the update (Well, what I could uninstall, anyways), and re-installed it (no effect).
I reinstalled my drivers on my graphics card (no effect).
I reinstalled my Codec CCCP (no effect).
I reinstalled Adobe Flashplayer (no effect).
I don't even know how to word this problem, or I'd do more extensive searching and research (like I usually do with my computer issues), but this time it's to a point that I cant even pinpoint a problem to look into.
Thank you for your time! Any help or links would be greatly appreciated!
just a guess...
it seems like monitor display / video card drivers is messed-up.
i know windows7 has built-in driver support, but,-Samsung - Display - SyncMaster P2770H/P2770FH (Digital)
try to roll back video / display drivers, if you can.
if you can not, try to install display monitor and video card drivers from OEM manufacturer. -
Doug looks like a Mii!
Try turning off Flash's hardware acceleration and see what happens. It almost looks like some sort of solarize or art filter is turned on. -
Yep, I cant find where to roll back those two specific drivers/update (I even looked at the windows live update log of updates, and the uninstall section, they weren't there...) I messed around with CCleaner to locate them, but with no luck.
I downloaded the drivers from their websites, nothing changed.
Tried this as well, nothin'. My videos do this, even with my .avi/.mkv files on my computer, they all have this weird color effect for video playback. But, pictures and games are fine. -
can you remove CCCP completely with all installed files from all possible locations and clean-up CCCP registry settings.
once un-installed completely. play same clips in WMP.
if WMP pops-up with a warning for missing-codec, try installing codec individually like xvid/divx, ac3, haali, coreavc but not the pack.
this is the last option.
if problems remains same then start all over again....long way to go... -
Your graphics card's driver has video filtering enabled. It's set to too much noise reduction and edge enhancement or sharpening. Turn those features off in the setup applet.
Wow, I didn't notice in my graphic card's settings that my Edge-enhancement, De-noise, Mosquito Noise Reduction, and De-blocking were turned WAAAAAY up. there was also a 'use settings on internet video' button enabled, so, no wonder it was effecting everything.
I feel silly now, thanks for all your help!
Update on ATI TV Wonder 650 USB Auto Gain Control (AGC) Issue
By Mini-Me in forum Capturing and VCRReplies: 7Last Post: 22nd Aug 2013, 09:39 -
VHS Color Saturation Issue
By Sckinhunter in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2011, 17:57 -
Color Issue Post BD Rebuilder encoding
By Brett4u6 in forum Blu-ray RippingReplies: 0Last Post: 6th Jul 2011, 14:58 -
color issue with Canon HF10 / HF100?
By boriskey in forum Newbie / General discussionsReplies: 21Last Post: 5th Dec 2008, 13:25 -
MJPEG to MPG2 color issue
By boriskey in forum Video ConversionReplies: 14Last Post: 23rd Dec 2007, 10:38
