My video camera outputs H264 at 720p. My PC doesn't have the processing power to edit this.
What free program should I use to convert H264 to an easier to work with format?
I would like to retain picture quality if possible.
I use MPEG Streamclip to convert to Apple Lossless Encoding (I use a Mac) but, of course, that format won't work for you. However, the app does support many other formats so, depending on the NLE software you use, you might find something in MPEG Streamclip's "Export to..." choices that will work.
Also check the choices you have in whatever NLE app you are using; it might have a "native format" it likes to work with and might do an automatic conversion to that format as it imports the footage. -
High bitrate MPEG 2 or h.264 with short GOPs. Depending on what your final output needs to be and what type of editing you need (ie, simple cut/paste vs. complex filtering).
What tool/s can I use to Mux/Edit H264 in FLV container? Avidemux only does
By tigerb in forum Newbie / General discussionsReplies: 9Last Post: 8th Dec 2011, 22:03 -
Convert h264 to what for edit/slow computer
By krisbee in forum Video ConversionReplies: 1Last Post: 13th Apr 2011, 08:58 -
Is there way to edit MKV (h264)?
By jiopi in forum Video ConversionReplies: 9Last Post: 18th Jan 2011, 22:19 -
Need to convert raw .h264 stream to edit in Vegas Pro 9
By cintec in forum EditingReplies: 18Last Post: 9th Aug 2009, 12:44 -
[help] edit H264 TS file
By ron007 in forum EditingReplies: 1Last Post: 2nd Sep 2008, 03:53
