When I was going to test my Capture Board, the audio got choppy.
But the captured files are not like this, the audio is just fine on these.
But for some weird reason, the playback is awful.
I don't get it, my old PC was a Celeron, and the playback was exactly like the captured file.
My old PC:
-ASUS P4P800-MX
-1gb RAM
-Celeron 2.2ghz
My new PC:
-Gigabyte GA-945GCM-S2C
-2gb RAM
-Pentium 4 2.66ghz
What could be wrong?
Results 1 to 12 of 12
Do you mean the playback within VD? It's an editor, not a player. Editors aren't optimized for playback. If the file plays normally in a decent player no problem.
Probably not related to your problems, but if you only have 2GB RAM, that's a bit small, unless you're running an older OS like XP. If you have on-board video, then some of that is used for video, making it even smaller.
And welcome to our forums.
Try the different sync options: Capture -> Timings. If you can't get it to work just turn off the audio playback while capturing, Audio -> Enable Audio Playback.
No, no, no. The problem's not on the capture, the audio is recorded fine.
The problem is just on the audio playback on VirtualDub Capture Mode.
When I play any recorded file, the audio is normal. -
Guys, I found on VirtualDub Capture Mode faq that the problem is because that I have a VIA chipset.
Is there anything I could do to solve it? -
I know what your problem is. Just turn off audio playback while you capture and audio sync won't be an issue -- you won't hear any audio while capturing. You usually don't need to hear the audio while capturing.
Then I would try a different capture program. There are many capture/viewing programs:
https://www.videohelp.com/tools/sections/capture -
I don't know if it has a solution or not for your computer. The point is, if you can't get VirtualDub working right all you can do try some other software.
VirtualDub Mod Conversion from DVD, no audio in FCE
By Jralph in forum Video ConversionReplies: 2Last Post: 29th Apr 2009, 10:09 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
TS audio playback is choppy
By autumnwillow in forum Newbie / General discussionsReplies: 5Last Post: 12th Nov 2007, 09:14 -
Choppy video when enabling audio playback
By Xytrasx in forum Capturing and VCRReplies: 1Last Post: 3rd Aug 2007, 06:01 -
Encoding audio with VirtualDub MOD
By GangstaRap in forum AudioReplies: 5Last Post: 19th May 2007, 07:20
