Hello everyone,
I have some HD video takes from a photocamera, specifically .mov files with 1920*1088 resolution (I don't know why it's not 1080), and a data rate of 45129kbit/s if it matters. No I want to make a simple movie with only these takes and I want to export it so that the quality of the source material isn't lost.
How do I do this?
So far I've used Pinnacle Studio HD 15, but the only formats with which I can export to 1920*1080 resolution are *.mov and *.wmv, but in both cases the quality drops significantly, like the resolution is lower even though it's a 1920*1080 file.
(I have Sony Vegas and AVID Media Composer installed too so if it's only possible with those kind of programs your answer will be helpful too)
I can't select a higher bitrate setting. Is the problem then just that Pinnacle Studio doesn't support it? Why wouldn't they?
Exporting DVD rip in 632x258 resolution while maintaining high quality HELP
By a404j in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 04:57 -
When exporting out of Premiere...
By bsuska in forum Video ConversionReplies: 20Last Post: 4th Jan 2010, 17:22 -
vegas exporting
By romanstopme in forum Newbie / General discussionsReplies: 8Last Post: 5th Apr 2009, 15:22 -
Exporting HDV
By adanchev in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 07:44 -
exporting .m2v source files out of fcp without quality loss
By MacNiles in forum MacReplies: 9Last Post: 17th Aug 2007, 08:39
