I have read a lot of posts on this site and others mentioning the same issue but I'm not having much luck following the same procedures mentioned to fix it so I'm starting a new thread. I apologize in advance if I missed another solution that might address my problem.
I record TV shows using WinTV and allow the program to automatically convert the output to MPEG-2 format (alternatively it can create .TS files). Using about a dozen authoring programs I am able to successfully create a DVD but the audio is missing. I can play the .mpg file using WinTV's player and other programs and the audio is present so it seems to be lost during the authoring process.
I successfully used ReJig to demux the audio and video into .m2v and .ac3 files. However, when I attempt to author DVDs using ReJig or IFOEdit the programs crash immediately. Muxman will allow me to browse to the .m2v file and select it but then it will not show up in the list of video files to confirm.
It would be nice to edit out commercials, add menus, etc., but at this point I would be extremely happy just getting the full recording with audio on a DVD that I could play outside of my PC.
When you record mpeg-2 with your capture device, does the captured file contain video and audio
that is DVD compliant, or are you expecting the encoding/authoring tool to re-encode your file?
The typical all-in-one programs typically recognize the streams as compliant (assuming they are),
skip the encoding,and go straight to the authoring stage. I'm thinking of "DVD flick", AVStoDVD,
ConvertXtoDVD, etc,etc.
When you say the audio from the DVD is "missing", do you mean the VOB contains video only (perhaps verified by opening
one of the VOB's with Mediainfo and looking at the stream info) - Or, it is present but doesn't play?
Also, any authoring program should leave a log. Have you checked it for errors.
Does your capture card create the mpeg file with mp2 or ac3 audio?
Could you post a mediainfo output of one of your captured files. Put it in view/text mode and
put the results in here. -
I tried using several all-in-one programs (Cyberlink DVD Suite Deluxe, Digiarty WinX) and they produced DVDs that I could play on my DVD player. However, there was no sound.
Following the boards I tried DVD Maker Pro and added the .m2v and .ac3 files I had demuxed using ReJig as I explained below. I noticed that it produced a DVD folder with an empty AUDIO directory.
Attached is the output from the MediaInfo for the most recent file I'm attempting to burn. I hope I answered your questions and I greatly appreciate any help...
General
Complete name : C:\Users\Public\Videos\5.1___WEWS-DT_20111219_2000.MPG
Format : MPEG-PS
File size : 6.31 GiB
Duration : 59mn 50s
Overall bit rate : 15.1 Mbps
Video
Format : MPEG Video
Format_Commercial_IfAny : HDV 720p
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=30
Duration : 59mn 50s
Bit rate mode : Variable
Bit rate : 14.4 Mbps
Maximum bit rate : 14.6 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.261
Stream size : 6.02 GiB (95%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Muxing mode : DVD-Video
Duration : 59mn 50s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -228ms
Stream size : 164 MiB (3%)
Text #1
ID : 224 (0xE0)-608-1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Text #2
Format : EIA-708
Stream size : 0.00 Byte (0%) -
It's 1280x720. Forget about authoring it. It has to be reencoded first to be DVD compliant. Maybe you're burning data discs, but not true DVDs.
Thank you. Both ConvertXtoDVD and AVStoDVD worked, but since AVStoDVD is freeware I will stick with that one. I guess I just hadn't tried enough software packages after all. Have a very happy holidays and thanks again for your help!
Converting Media Center Cablecard recorded shows
By pcostanza in forum Newbie / General discussionsReplies: 5Last Post: 19th Apr 2011, 07:44 -
Converting AAC to AC3 (for DVD authoring), losing audio
By senorroboto2k5 in forum AudioReplies: 3Last Post: 16th Feb 2010, 18:03 -
How do I transfer shows recorded to hard drive to DVD?...
By Tigergreg in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2008, 19:35 -
I Can't Play Back Recorded Shows
By ttibsen in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2007, 09:54 -
recording shows I have recorded on my sat. DVR
By djohlson in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2007, 19:48
