Good morning is Stephen.I installed FFMPEG for mac lion I get this error
I cam help you install.Grazie
The installation was not successful.
##sudo: /private/etc/sudoers is mode 0644, should be 0440
sudo: no valid sudoers sources found, quitting
Results 1 to 11 of 11
I never had a chance to use ffmpeg in Mac OS X Snow Leopard, never tried to updrage it to Lion as everything is perfectly set-up and working just fine beyond imagination.
But, the procedure for ffmpegX would be same like other codecs.
Get ffmpegX either from VideoHelp or from here,
And simply follow these steps:
1) Control-click on the ffmpegX application, choose Show Package Contents from the pop-up menu, and navigate into Resources.
2) Copy ffmpeg to /usr/local/bin.
3) Execute the following in Terminal (as admin):
sudo chown root:wheel /usr/local/bin/ffmpeg
sudo chmod 755 /usr/local/bin/ffmpeg
4) open the terminal, and type
ffmpeg -h
if you see help, its already running in terminal.
Hope this will work for you.
Mac OS X Lion QuickTime Player Choppy Audio
By zBernie in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 21:05 -
ffmpegX 0.0.9y-L for Mac OSX 10.7 "Lion" released
By major in forum ffmpegX general discussionReplies: 10Last Post: 29th Jan 2012, 04:27 -
ffmpegx on Mac OS X Lion?
By tio00 in forum ffmpegX general discussionReplies: 19Last Post: 31st Jul 2011, 04:15 -
Installation Failure on Mac 10.6 ffmpegX 0.0.9y
By metalhaze in forum ffmpegX general discussionReplies: 5Last Post: 20th Oct 2010, 12:41 -
FFmpeg autobuilds for Mac OS X
By Chris K in forum MacReplies: 0Last Post: 21st Jun 2010, 13:45
