Hi All,
I've just pruchased the above TV, and have been given a few 3D SBS blu-ray rips by a friend. However some of the mkv's do not play on the tv i get file not supported errors, where as others play fine.
What do i need to do to get these files working, guessing its a codec issue somewhere
File dthat doesn't play
General
Unique ID : 209272299082846975438355149652834442480 (0x9D7060F4ACC1C5D7AD74EECAA9C4DCF0)
Complete name : F:\3D Blurays\Toy.Story.3D.1995.1080p.BluRay.Half.SBS.DT S.x264-HDMaNiAcS\Toy.Story.3D.1995.1080p.BluRay.Half.SBS. DTS.x264-HDMaNiAcS.mkv
Format : Matroska
Format version : Version 2
File size : 6.61 GiB
Duration : 1h 21mn
Overall bit rate : 11.7 Mbps
Encoded date : UTC 2011-11-03 01:55:53
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 21mn
Bit rate : 10 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.201
Stream size : 5.62 GiB (85%)
Writing library : x264 core 118 r2085 8a62835
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=10 / psy=1 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Codec ID : A_DTS
Duration : 1h 21mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 876 MiB (13%)
Language : English
Default : Yes
Forced : No
File that does
General
Unique ID : 206449472392379697491696953773405484208 (0x9B50B8DAC81A0395B5C3B271721FB4B0)
Complete name : F:\3D Blurays\despicable me\Despicable Me 3D Half-SBS.mkv
Format : Matroska
File size : 7.44 GiB
Duration : 1h 34mn
Overall bit rate : 11.2 Mbps
Encoded date : UTC 2010-12-09 01:50:22
Writing application : mkvmerge v4.3.0 ('Escape from the Island') gemaakt op Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.0
Duration : 1h 34mn
Bit rate : 9 497 Kbps
Nominal bit rate : 10 000 Kbps
Frame rate mode : Variable
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.191
Stream size : 6.29 GiB (85%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 34mn
Bit depth : 24 bits
Stream size : 1 024 MiB (13%)
Default : Yes
Forced : No
I have tried H.264 level editor to bring level down to 4.0 but still doesnt play
Any help much appreciated
Many Thanks
Nathan
Closed Thread
Which format for panasonic viera TV
By kode in forum DVB / IPTVReplies: 47Last Post: 14th May 2014, 10:31 -
panasonic viera xseries mp4 porblem
By bensonoommen in forum Video ConversionReplies: 3Last Post: 17th Feb 2012, 12:52 -
SD card for panasonic viera
By gamergaz in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2011, 19:31 -
Panasonic Viera TX50V20 TV will not play AVCHD
By dobien in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2011, 09:47 -
Panasonic Viera with Dynex DVD and FIOS Remote question
By zumata in forum DVD & Blu-ray PlayersReplies: 4Last Post: 21st Feb 2011, 13:23
