Hi, I'm quite a newbie. I've been using an Azden WR / WM-PRO lav mic to do a video. Works pretty well.. but now I'd like to do a podcast.
I like the sounds of these lav mics, but I'd like to have a third person. Ignorantly purchased 3 of them thinking they would be on different channels.
So here's where I'm at. It seems the best thing to do is just purchase a Snowball for any guests. The other issue is that I've not been monitoring the sounds. I suppose if I were to do things right I'd get:
3 headphones
Headphone amp - http://www.amazon.com/gp/product/B0010BWLMS?ie=UTF8&tag=onmasbl-20&linkCode=as2&camp=1...SIN=B0010BWLMS
Proper mics - http://www.amazon.com/gp/product/B000Z7LLQ0?ie=UTF8&tag=onmasbl-20&linkCode=as2&camp=1...SIN=B000Z7LLQ0
A mixer - http://www.amazon.com/gp/product/B000J5Y214?ie=UTF8&tag=onmasbl-20&linkCode=as2&camp=1...SIN=B000J5Y214
(though this mixer wouldn't handle the Snowball I assume)
I also own a BlueBird condenser mic (with a pop filter) that I use with a Apogee ONE pre-amp to record onto Logic. I could use that instead of a Snowball.
The main thing is how to get all this stuff to work together. I'm was looking at a video on Audio Hi-Jack and Soundflower for recording, but I have Garageband and Logic (could install Mainstage).
At the end of the day I'd like to have a video podcast, but just with photos I lay over the audio track. I don't want to spend a lot of time editing and I'm just getting started so I'm looking to keep my budget as low as possible while using the top low-budget items.
Suggestions are all welcome!
Chris
Results 1 to 1 of 1
Lav filter and avisynth
By Creed in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2011, 17:10 -
Capturing sound from 2 lav mics and 1 shotgun with Panasonic HDC-HS700
By Big Chupa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Jul 2011, 00:20 -
Wireless Mics for hunting
By buckdude in forum AudioReplies: 6Last Post: 30th Aug 2010, 22:45 -
Can I use two stereo mics or do I need two mono mics for stero?
By Graham Archard in forum AudioReplies: 2Last Post: 18th Mar 2010, 00:08 -
Podcasting Woes
By hellfire45 in forum AudioReplies: 3Last Post: 30th Sep 2009, 00:33
