Hello,
I recently upgraded my in car dvd player to a pioneer avh 6300bt. The reason was because i was tired of having to change disks and wanted to play movies and videos via a usb thumb drive. I am trying to convert one of my dvds to an avi or divx so that my unit can read the file but am having some difficulties.
I have tried using dvdfab 8 dvd ripper(bought and paid for) various other trial version software to convert the dvd. When ripping, I use the generic.divx.audiocopy option. I am successfully able to play the new avi (after dvd conversion) on my computer but the car unit says "unplayable file"
I have looked into the specs of the unit and it just says "supports .divx and .avi". So I feel like i am missing a step in the conversion process. any help or advice would be great.
Thanks in advance.
resolution:
I figured out what the problem was. It was actually the USB drive. Windows 7 cannot format a thumb drive greater than 32Gb in the fat32 format. The unit in question can only support fat32 or fat16. once reformated divx avis will work.
p.s. I know it can play videos from usb because after installation, i had the guy at the store plug in a usb thumb drive of his own with an avi on it and it played the movie fine. My thumb drive is a 65gb one as well (not sure if that would be the issue)
Run your videos through MediaInfo, in Tree View, and see if anything in those details conflicts with the issues in this post: Common DivX DVD Players AVI Playback problems!
Alternately, you can copy the text from MediaInfo's analysis of the video and paste it here; someone might be able to notice what your player doesn't like about the video(s).If cameras add ten pounds, why would people want to eat them? -
Below is the media info for the avi constructed using dvdfab dvd ripper. It seems that I meet all the requirements listed in the common divx dvd players avi playback problems (unless i'm missing somthing)
General
Complete name : M:\avi\GREEN_LANTERN\GREEN_LANTERN.Title1.avi
Format : AVI
File size : 787 MiB
Duration : 1h 54mn
Overall bit rate : 965 Kbps
Movie name : GREEN_LANTERN.Title1.DVDRip
Writing application : Lavf52.78.4
Original source form/Name : GREEN_LANTERN
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 54mn
Bit rate : 888 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.169
Stream size : 724 MiB (92%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 53mn
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 52.2 MiB (7%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 24 ms
Writing library : LAME3.98.4
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Pioneer AVH-P5050DVD
By pperie in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 16:45 -
Need help to region free a pioneer AVH-5200BT
By Altahlus in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Apr 2010, 16:42 -
Divx 3 AVI files for my Pioneer AVIC D3
By cbeausoleil in forum MacReplies: 5Last Post: 19th Aug 2008, 23:59 -
Need Region Code Hack for PIONEER AVH-P5900DVD
By kratzy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Dec 2007, 10:14
