I just recently backup allmy dvd's into my PC, I used AnyDVD software and removed all extras, just keepingthe movie. I was playing my first movie and when it reach half way, as onechapter finished, it went back to the beginning of the movie. If I skip beforethe end of that chapter it does continue with the normal progression of themovie, but if I leave it running normally it goes back to the beginning.
I don't know if all moviesare like this or only this one. Is there a way to edit this and fix it?
I am going to check othermovies later and see if this a problem with all, is there a way to avoid thissince the beginning?
Regards
Gabriel
				Results 1 to 14 of 14
	all my dvd I backup as Video_TS. Can I do this with DVD shrink? Is there another way to try to fix the file?
	Yes, you can use dvd shrink. Select Open files and choose the video_ts folder.
	thanks a lot, I already did one Movie and seems to work perfectly, I will now try to redo the one that was skipping.
	ok, so it wasn't that easy. I tried the movie that skips and I get an error in DVD shrink.
 "DVD shrink ecountered an error an cannot continue.
 Failed to read file E:"
 I had this error in two movies already.
 is there anything I can do?
	Are you running anydvd in the background? DVD SHrink can't handle newer dvds.
 Another solution would be to use dvdfab dvd copy. It can copy the main movie. Not free though.
	I decided to backup the whole movie, I thought this was going to fix the indexing problem, still the movie goes back to the beginign at the end of a giving chapter. this seems to be a bigger issue that just eliminating the extras.
 is this problem normal? or I am doing something wrong here?
	Are you launching the movie by using a .VOB file? If so, don't. Launch it with the VIDEO_TS.IFO file.
	I am using Windows Media Center to play the movies, It picks the file by it self, I asusme the right one? This is under my file structure of my videos and subfolders for movie, etc.
 some movies are working fine, but other still skip or repeat some chapters.
 stil can't find the solution.
  computer restarts while encoding video with Handbrake. please help.By christessmer in forum Video ConversionReplies: 26Last Post: 19th May 2022, 08:58
  Restarts with no provocationBy dadrab in forum ComputerReplies: 16Last Post: 10th Oct 2008, 15:56
  Computer Restarts RandomlyBy peomp in forum ComputerReplies: 26Last Post: 18th Jul 2007, 02:07
  TMPGEnc encodes to 1%, then my PC restartsBy Syntax in forum ComputerReplies: 3Last Post: 5th Jul 2007, 17:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
