Hi everyone. I have been trying for several days to convert QAM(WTNH-DT, WSFB-DT...) tv shows with freemake video converter. The files are convertered to wmv, but the audio is out of sync. The audio is ahead of the characters voice. It is distributing. How can i fix this problem?
My PC specs are:
Windows 7 X64
Intel(R) 2 Duo Core CPU E7500 @ 2.94 GHZ
6 GB of Ram
Direct X 11
Freemake
Hauppauge 1850
Hauppauge 1600
Hdmi connection to tv
Any assistance will be appreciated. mary
If you convert to another format in freemake do you also get sync problems?
You could try another all-in-one solution like format factory, any video converter free.
And post the full details from your video source, use mediainfo. -
Hi Baldrick. I tried to use the Any Video Converter on a tv show--Hart of Dixie-- and it did not convert it. It failed with no error code.
I am uploading the information concerning the file. Thank you for helping me. mary
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
