Hi
several questions
1) i have imac, and i am using makemkv to ripp bluray movies to MKV, it works fine, but then i convert the mkv to DBMV(tsMuxter) so i can burn it to a bluray disc, once i am doing that, i loss capacity from 23G (mkv) to 800M ish , how can i avoid loosing quality here
2) when i load the DBMV to toast 11 so i can burn it, i get a messae that i need to convert the file to PAL ( i am not sure why since my bluray DVD player is pal and played the original disc just fine) , in preferences the standard TV sets to Pal,
but i am wondering why do i need to conver the file to PAL, as it was taking from original PAL bluray disc.
3) does burning DBMV is the right chioce to burn a bluray disc with? i am having sony S350 bluray player
Thanks in advance
It's probably better to use something like DVDFab Blu-ray Copy or Pavtube Blu-ray Ripper for Mac and make an iso and burn. Not free though.
I don't know any good method to convert the makemkv mkvs back to a blu-ray/bdmv.
And I'm moving you to our mac section.
edit: Or well , http://www.dvdfab.com/hd-decrypter-for-mac.htm is free but it can't make an iso though. -
ok, i just want to be clear here
the pavtube create an iso image out of the blu-ray disc ( original disc), but what if the blu-ray disc is protected,
does pavtube making any decrypting action in parallel ,so the iso image ready to be burn properly ?
cheers -
Try the free trial?
But I'm sure the full version of DVDFab Blu-ray Copy can make an iso. See http://www.dvdfab.com/blu-ray-copy-for-mac.htm
Bluray ripping my bluray collection
By NoLegalMoves in forum Blu-ray RippingReplies: 4Last Post: 24th May 2012, 09:39 -
Bluray Ripping on my macmini
By BIFFtheSTIFF in forum MacReplies: 8Last Post: 3rd Jan 2011, 13:49 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 14:05 -
HD-DVD to BluRay Ripping
By amadeira in forum Blu-ray RippingReplies: 4Last Post: 25th Jun 2010, 21:33 -
Bluray ripping programs?
By Browncoat in forum Blu-ray RippingReplies: 11Last Post: 16th Nov 2008, 21:44
