Hi,
i have an avi but it wont play, only the sound can be heard. I figured out im missing a codec so i used mediainfo in order to learn which one and i got this:
so i downloaded the MS MPEG-4 v1 codec and installed but still there is no image when i play it, only sound. I have Windows 7 and i thought i had all codecs up to date but seems like i missing something. Any hint please?Video
Format : MPEG-4 Visual
Codec ID : MPG4
Codec ID/Info : Microsoft MPEG-4 v1
Codec ID/Hint : MS MPEG-4 v1
Thank you.
Nevermind, i just installed a windows 7 codec pack and now i can play it fine on WMP but the picture looks weird in divx player. Is that normal?
Microsoft MPEG-4 may mean what we normally call VC-1. If so, then yes, I would fully expect Divx Player to have all kinds of problems with that.
VLC is free and beats the crap out of WMP for playback. You might get a copy and try it. -
Yes, i already have VLC player, thank you. I just wanted to make sure it was normal for divx player not to play properly a movie with that codec.
sony DAV-HDX589W multi code zone code
By sam1821 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th May 2010, 15:37 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37 -
HTML code suitable for different sized Monitors; also code to embed
By wiseant in forum Off topicReplies: 3Last Post: 8th May 2008, 18:14
