So, I'm putting together a little home movies project that involves creating a DVD for strictly 4:3 material in DVDLab Pro 2. However, I would like to create 16:9 menus for the DVD.
So, this forum thread (http://forum.doom9.org/showthread.php?t=105613) suggests that I can change the AR of the menus, without affecting the movies to 16:9 by going into VTS properties. However, when I compile the discs and test them in AVS and Media Player Classic, everything is in 16:9, not just the menus.
What am I doing wrong and how can I fix this.
Results 1 to 13 of 13
Yes. I did.
All of the video content is uniformly 4:3, and shows up as such in Assets. It's just the menus are widescreen, but MPC and AVS display everything in widescreen. -
Opened the files with G-Spot. VTS_01_0.VOB (menu content) is 16:9, but all the other VOB files after that are 4:3 (the video content). Everything is MPEG-2, no issue there.
So, why does Media Player Classic's playback not reflect changes in DAR.Last edited by Super Leviathan; 19th Dec 2011 at 20:43.
you can't mix 16/9 and 4:3 content in a single vts. the movie would have to be put into it's own vts.
I was under the impression that would couldn't mix 4:3 and 16:9 MOVIES in the same VTS. The movie content is all 4:3.
It looks like a compilation is OK. It may be just a player that interpret it wrong. Try to born test end play it on stand alone DVD player.
I tend to disagree with this statement. I have seen many pro DVD with Menu in 4:3 and Title with 16:9 and it play fine.no the first thing that plays in a dvd vts sets the format. if it's a 16/9 menu the entire vts must be 16/9.
if you know what you're doing you can mix them with multiple vts's, 16'9 encoded as 4:3 or a kludge.
Question about Premiere Pro's aspect ratio math
By Asterra in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2011, 08:15 -
How to change menu aspect ratio in DVD-Lab Pro ?
By V879 in forum Authoring (DVD)Replies: 2Last Post: 1st May 2011, 16:11 -
Vob2Mpg Pro problem with extracted MPG aspect ratio
By Spoon_Lover in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Oct 2010, 03:20 -
Need help with aspect ratio woes after rendering/converting
By mpalm887 in forum Video ConversionReplies: 8Last Post: 26th Jan 2010, 02:45 -
Final Cut Pro Aspect Ratio Question
By Jeff_NJ in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 10:25
