OS 10.7.2
Movieconverter Studio V1.6
I'm curious to know if any other uses experience the following problem, before I report a "bug".
Converting an avi (or other type of file) to MPEG2, the process starts but seems to hang.
The indicator bar at the bottom of it's window stops. If I click on the Movieconverter Studio window the program seems to start up again. The progress bar starts moving.
It's rather annoying when trying to do batch processing overnight. The first process will complete, the others will just sit until I click on the MCS window.
tahnks all.
Robert.
Have you checked the Task Manager in Windows to see what the CPU usage is when it hangs?
I've seen similar things with other apps if there is a contention for the CPU and the hanging apps CPU priority is
lower that the competing apps. -
Hi (I'm its author
do not fill it
I completly rewrite (from scratch) the new version, so the "old one" (the current release) is "almost discontinued for me" (I will not update the old one, I am on the newer one only
I still have 2 bugs to correct and I will release the first beta (eg: this one is fully compliant with Lion)
So, just wait a little
here is the link (not yet activated today, but soon) : new -ßeta- version
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
How do you blur selected frames in AVIsynth?
By Nagashi in forum EditingReplies: 4Last Post: 9th Jan 2011, 20:30 -
Selected input is not BD format
By Mark AL in forum Authoring (Blu-ray)Replies: 8Last Post: 5th Oct 2010, 03:30 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 19:27 -
RipBot264 Question Regarding Demuxing Selected Streams;
By vrblkent in forum Blu-ray RippingReplies: 7Last Post: 29th Dec 2008, 19:25 -
DVD to AVI with selected subtitle language
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2008, 18:45
