As the topic suggests, I've got a 1920x800 MKV and I need to turn it into a BDMV that will play on a Bluray player (and not just the PS3). I already made a disc that ought to work, and it plays fine in Arcsoft TotalMedia Theatre... except that it stretches those 800 lines to 1080.
I am basically hoping there is some flag or setting I can try using which will enable me to use this h264 encode on a Bluray disc without having to compromise the quality (and introduce other complications) by re-encoding it with black bars.
Edit: I made the disc with TsMuxer.
The ArcSoft video decoders are rather limited --- they are OK for playing "BD-ready" files, but as you have seen, they were designed to "think" all videos must have a 16:9 aspect ratio
You'd better get a device that supports Hi-Def MKVs --- the BD-Video specs do not include "1920x800", for exampleI am basically hoping there is some flag or setting I can try using which will enable me to use this h264 encode on a Bluray disc without having to compromise the quality (and introduce other complications) by re-encoding it with black bars.
How to convert a BluRay disc into a .MKV 720P file
By ioannis66 in forum User guidesReplies: 26Last Post: 22nd Oct 2013, 13:45 -
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 14:39 -
If MultiAVCHD is not supported, what is good tool to convert MKV to Bluray?
By Yanta in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2011, 02:38 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05 -
full bluray disc to mkv or avchd
By Melvin18 in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Apr 2010, 11:26
