How can I remove subtitles from an m4v (mpeg4) video file? There are 3 seperate subtitle options that are selectable within the video (I can see the 3 subtitle options in VLC player), so are not embedded as part of the video-but are part of the m4v file-if that makes sense!
In VLC Player, stream 1 is my mpeg4 video, and stream 2 is aac mp4a audio.
Streams 3,4 and 5 are "subt" files - is there a program I can use to extract and remove these streams from the video? I know I can watch the video with subtitles disabled, but I am trying to find out the easiest way to remove these 3 streams without affecting quality?
thanks for any help
Remux with mymp4boxgui or yamb or mp4muxer. Open the m4v/mp4, remove the subtitles, save as new mp4.
I tried the yamb gui for mp4box, and that removed the subtitle streams with no issue from the original
I initially tried to extract the subtitles first so I could analyse them before removal (as I was having a problem with one of them) but yamb gave me an error (could not find mp4box) even when I had given the location. thanks
remux from m2ts to m4v/mp4 and remove scan type MBAFF
By jlally in forum Video ConversionReplies: 9Last Post: 18th Apr 2012, 05:01 -
Change m4v subtitle track language
By Kurgan71 in forum SubtitleReplies: 2Last Post: 19th May 2011, 10:42 -
convert avi with subtitle files (.sub & .idx) into .m4v with soft subs?
By The Nemesis in forum Video ConversionReplies: 1Last Post: 6th Mar 2011, 21:40 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 12:25 -
Seeking in MPEG2/MPEG4 streams in MPlayer
By zuja9 in forum Software PlayingReplies: 0Last Post: 3rd Jan 2010, 09:24
