    Dec 2011
    wdqwfqwfw
    Is it compatible with my computer? My computer came out this year
    Heres the Specs
    Processor: Intel i7
    Chipset: Sandy Bridge
    Graphics Card: Intel Graphics
    usb 3.0: Yes, It actually came in the motherboard itself.
    .... So my question is... Can i handle it?
    Aug 2006
    Since you are reluctant to give much in the way of computer details, you can find links to follow for the technical requirements at http://www.blackmagic-design.com/support/detail/supportnotes/?sid=3947&pid=4042&os=win
    However, the mere fact that you can't go to BlackMagic Design's website yourself, find what you need to know, and understand what it says, leads me to question whether you have the background to successfully use an Intensity Shuttle. This is a serious piece of equipment, not intended for use by those without much technological expertise.
    [Edit]I forgot to say that onboard graphics supplied by the CPU are not enough. BlackMagic Design recommends a discrete accelerated graphics card.
