Could anyone tell me how to make Subtitle Edit play sound in AC3 format?
As an alternative to what says Baldrick, if you set in Subtitle Edit (menu Options -> Settings -> tab Video player) the playback with VLC media player (not with Windows Media Player), you should have any problem, because you don't even need to install the AC3 codec.
Obviously, first you must have the software VLC: download the portable version of VLC media player and copy the entire contents in the subfolder of Subtitle Edit named VLC.alvin68
"...un alieno su questa terra" -
Thank you very much. VLC did it.
Windows Media Player played the sound too, still Subtitle Edit did not. Apparently it does not use the computer's default player, but something built in it.
Subtitle Edit Help
By Soixante in forum SubtitleReplies: 0Last Post: 15th Jan 2012, 15:46 -
subtitle doesn't show in MPCHC
By alexanderex in forum SubtitleReplies: 2Last Post: 28th Feb 2011, 21:45 -
Edit Subtitle Megui
By bebado22 in forum Video ConversionReplies: 2Last Post: 28th Sep 2010, 22:13 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 18:57 -
subtitle that doesn't fit
By Belfour in forum SubtitleReplies: 5Last Post: 14th Aug 2007, 09:30
