Hey,
Small problem - i have a movie here in *.avi format. I want to convert VCD format. I know how do to this (done it many times before, all worked fine) but i have come across something that just has me stumped.
First off - The there is two avi files both 700 megs (DVDRips) i didnt encode them. Using virtual dub i wanted to extract (uncompress) the audio from it. I am using a guide that tells me to uncompress the audio to a wav file (to use with TMPGEnc). When i try and do this Virtual dub is telling me that it does not recognise the compression format of the audio in the avi file. When i use Virtual dub to get the file info this is what is displayed -
Video Stream
Frame size - 640x272, 23.976fps
Decompressor - DivXMPEG-4 Low-Motion
Audio Stream
Sampling - 48000hz
Channels - 5(Stereo)
Sample Precision - 0-bit
Problem bit - Compression - unknown (tag 2000)
I know there is no need to get the Wav file but it works out better if i do.
I then taugh that maybe whoever encoded the file changed the file extension manually (it is a 700 megs file - only 58 mins long - sounds like it is mpeg already), but that is not the case either (virtual dub loads up the file instantly (if it was mpeg it would take a min or 2)
Secondly, i tried something else
Gave up on the wav file and said i just use TMPGEnc, using the avi file as the video and audio source.
When i tried this it only loaded up the file for the video, when i tried to load the same avi file for the audio it gave an error message (Can not open OR Unsupported)
Has any one come across this problem.
I was thinking that maybe what ever audio coversion codec was used, i dont have installed on my machine. I have quiate a few so maybe there is some obscure one out there that i never heard of.
Anyhelp would br much appreciated
Cheers
stehaz
Results 1 to 1 of 1
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 14:03 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 19:00 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 13:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 19:45
