I recently bought am Oneforall URC-7960 trying to unlock my Sony BDV-370, however, I can't find the "Magic button" on the remote control. Also DVD is not a button on the remote... Can anyone help me on this? Thank you so much for your help.
Best regards,
Azuma
not all bluray/dvd players can be made region free(if you bought it from usa/canada). you do know if you did get this to work only the dvd part will be region free and not the blue ray side.
Hi October,
Thank you for your reply. I understand that not all players can be made region free. The one I have is with region 3 DVD, and region A BD. Someone has post the unlock code on the hack list. The problem is that the I can't not find the buttons mentioned in the unlock instruction on my Oneforall remote which is model URC-7960. If anyone who has the Oneforall URC-7960, please kindly help me here! Thank you so much.
Best regards,
Azuma -
I think I figure it out the the "setup" button on URC-7960 is the "magic" key~ Let me try if it works.
Azuma -
Sony BDV-e880 - do not play 3D MKV
By esergim in forum Blu-ray RippingReplies: 8Last Post: 29th Feb 2012, 14:10 -
Sony bdv-iz1000
By gymmerman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Aug 2011, 15:31 -
sony bdv-e370 will not play bd25
By davechubb in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2011, 13:21 -
Region hack for Sony BDV-F500
By Black-N-Jacker in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Jun 2011, 15:34 -
Applying kameleon 6 URC-8206 instructions in a OneFor All URC-8820
By garciamaki in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jul 2010, 11:01
