Got a DVD to rip this weekend that had major scratches. Even when I played the movie in my player, the scratches were too deep for the player to ignore them, so playback pretty much halted for a minute. I tried to rip the disc and ran into this same problem. Smart Ripper only lets me rip in chapters. Is there a way to rip specific segments to their own VOB files, so I can pass over the bad scratch on the disc?
I know with audio cd's you can fillin the scratches with tooth-paste. May want to ask around before doing this with a DVD but I know it works with Music CD's
I've got the exact same problem with a vcd at the moment that I lent to a friend
I've smothered the scratch with tootpaste and let it dry. Now what do I remove the excess with??
This sometimes works for scratched disks .... use Brasso on a soft lint free cloth and make circular strokes over the disk. Buff off any Brasso residue with a clean lint free cloth and if you've got any you could give the disk a clean with some IPA (iso-propyl alcohol).
Would be best to try this out on a old CD disk. Get some practice before wrecking your DVD
BE WARNED: This may not work but if your DVD is gubbed then it has got to be worth a try!
GOOD LUCK -
First of all you NEVER want to rub in any other way except: From the inside of the disk outwards.
Just put some toothpaste on a lint free cloth and drag it from the inside out. In theory you can wipe it clean, the tooth paste will fill in the scraches.
Hope this helps
Help extracting data from scratched DVD.
By nemy009 in forum DVD RippingReplies: 9Last Post: 5th Nov 2011, 00:26 -
Can anything rip scratched but playable DVD?
By miamicanes in forum DVD RippingReplies: 17Last Post: 3rd Nov 2010, 17:27 -
Can You Fix A Scratched CD DVD With Toothpaste?
By vp0baby in forum DVD & Blu-ray PlayersReplies: 9Last Post: 10th May 2010, 20:44 -
How can I recover a scratched dvd/
By wan2no in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 03:48 -
What player for scratched DVD's?
By mad_max911 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Sep 2007, 10:43
