I have a new macbook pro and a component capture device. I got it online for 20 bucks.
http://www.amazon.com/DBTech-Video-Audio-Capture-Device/dp/tech-data/B0069A1NQU/ref=de_a_smtd
The mac isn't recognizing it. I am using free software called Debut I found online. I know it says windows on the description, but I figured the Mac would still be able to recognize it. Is this happening because I need specific drivers for the device? Did I just waste 20$
Did you waste $20? Probably.
Macs aren't Windows machines, as you just found out. I wouldn't buy ANYTHING for use on a Mac without reading the manufacturer's certification that it works on Mac. Yes, you will need Mac specific drivers for the device. My guess is that the manufacturer didn't bother to make any.
This is one of the very few USB based capture devices that I know of that works on a Mac:
http://www.hauppauge.com/site/products/data_hdpvr.html
You're not going to like the price of it though. And Hauppauge doesn't support it on Mac but a 3rd party does, which entails more expense as you have to buy their software to get it to work. -
Elgato is the king for Mac capture They have a similar model to the HD DVR called EyeTV HD.
http://www.elgato.com/elgato/na/mainmenu/products/EyeTV-HD/product2.en.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
Easy Cap USB 2.0 Video Adapter
By Joy123 in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2011, 08:53 -
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 14:40 -
component install trouble
By threelibr3s in forum ffmpegX general discussionReplies: 1Last Post: 28th Oct 2008, 13:30 -
Need USB/Firewire 480p capture over component
By Try4ce in forum Capturing and VCRReplies: 2Last Post: 3rd Jan 2008, 16:50
