Hi Guys,
Dorking around with VB.net express i decided to create a front end to some common tasks i find that i
find myself doing constantly- repairing indexes (MKV & AVI), packing/unpack b-frames & changing fourcc
For my standalone or a family member/friend.
Here's how it works.
appname: Mybatch
Drag/drop or double click listbox to load file(s).
-what i do for the 100+ files and 300+ directories is use
Search for *.* and drag the files onto the gui.
- for now file types have to be the same for the task
select the radiobutton for the specific task
- you can edit the default cli args by right clicking and choosing 'edit scripts'
finally press the execute button.
Cmd.exe will open and process the batch file 'script.bat' in the application directory.
I plan on creating 'new' button to reset listbox and append new tasks to 'script.bat'
I will probably finalize the 'save bat' option and enable mpeg4modifer/fourcc changer options sometime this week
and -maybe- clean-up the the root application dir by organzing the resources. Maybe adapt for more advanced tasks such as soopafresh scripts.
There's a GUI.INI in the application root - change the labels, radiobuttons names to whatever you want
or translate for a friend but don't change the order. There's a Proj.ini in the app root where you can save listbox
collection for later processing.
Again, this is for me is to be used for repair tasks but theoretically it can be customized to do whatever (i think!)
No coding expert here either just having fun learning.
Any Suggestions? Let me know what you think. I would especially like opions on the scripts used for the batch file and what you consider generic cli args for fixing avi's and mkvs (with mencoder & mkvmerge) . There's a mkclean.exe app i don't know if its worth having I did some tests and didn't notice much differences, just fooled around with the mkclean 'optimize' arg.
- Thanks!
Results 1 to 11 of 11
Last edited by VirtualDoobMon; 21st Dec 2011 at 15:33. Reason: 21/12/2011 - fixes & added a few more features.
Hi Guys,
Updated a few things.
Remember, this is nothing more than a batch file generator for those who
wish to do exact same tasks for x amount of files with various freewares.
Reason i created this was i hate dealing with dos & FOR commands and the file name headaches.
The scripts are all the things i find myself doing when needing to repair videos (ie torrents) ..
You can change the default options by loading a file and right clicking over the UI and selecting
'change scripts' then saving. For example, the default for MPEG4Modifer is --unpack but you may
want to use --pack instead. All the scripts can be modified for the various tools so use as needed for your
needs.
The 'Save/Add to batch' button will ADD - just overwrite your saved batch file to append new tasks.
Here's whats available so far:
1. repair avi files (fix index)
2. repair mkv files (fix index)
3. change fourcc
4. pack/unpack bframes
5. ffmpeg to easily change container formats (ie Avi > MKV)
Hope you find it useful. I will periodically update as needed. -
Hi, thankyou so much for your effort, this it pretty much what I've been looking for for long time now.
I'm testing your utility as I write.
One thing that I noticed and it would be much appreciated is the possibility to recursively scan a root folder and pick up automatically video files
e.g. if I have a
I need to manually scan the subfolders and add video files only. how about instead having the utility scanning subfolders and picking up e.g. *.avi or *.mkv?Code:dir1/subdir/subdir/myvideofile.avi
2) Still talking about batch processing, how about having a function to first check the index and rebuild only if this is broken?
I have many videos and some of them have broken indexes, with this recursive import and index checking your utility can really help a lot!!! Thanks
many thanks! -
No problem and thx for the feedback. I'll look into those requests when I have time.
Sent from my GT-I9000 using Tapatalk 2 -
I know this is a very old thread, but I just had to say thank you to VirtualDoobMon for this gem. I just got a Sony BDP-S5100 (which I absolutely love) that won't play Divx and had to use 4CC Changer on hundreds of files. This thread and its tiny GUI that still has a working link to download has saved my sanity and a LOT of my time, it works great to do hundreds of files at once in a minute.
I'd like to echo Henderson's comment. This is the only utility I've been able to find that allows for batch changing FourCC's. And since I have several thousand DivX files that my Blue Ray player won't play unless I change the FourCC, doing them one at a time would turn my brain to mush pretty quickly.
The only thing I wish it had was the ability to choose which FourCC to apply to the files, but I can use a text editor on the resulting batch file and modify the codes pretty easily, so it's not a problem.
UPDATE: Just finished changing the 4CC's on just over 4,000 files across 4 different drives in a little under 15 minutes, and that includes editing the resulting batch files with a text editor to change the 4CC to MP4V instead of XVID (because I was getting inconsistent playback results on my BluRay player using XVID). I can't even imagine how long it would have taken to do the same thing one file at a time.Last edited by awgie; 25th Feb 2014 at 19:56. Reason: Updated to report results
Do or do not. There is no "try." - Yoda -
What a fantastic find this tool is, and a big thanks to VirtualDoobMon for the effort.
Have saved many, many hours processing my avi's.
regards. -
I have been looking for something like this for long time!
I'm really grateful and would like to contribute my way to this software, with a couple of suggestions:
- Reindexing myvideo.mkv creates a file called myvideo.mkv.mkv it's fine with me but it would be nice to have an option to remove the old file and rename the new one as the old one (sounds like overwrite new on old)
- I would be also nice to check if the index has problem before taking any action. This would solve the batch processing of large libraries
- a simple control to manage the queue would help a lot like add,remove,move elements in the queue
- a pause and run N elements in the queue would also be nice to have (do consider batch processing of 1000s of videos)
- a GUI function to accept in input a root folder and process al the subfolders to find and add to the queue only video files
- repair of mp4 would be very much appreciated
Thanks! -
It's been years since this was first posted, & I just wanted to say "Thanks!" My LG DVD player won't play DivX unless the FourCC is changed, & this tool makes it a breeze. Again, thank you.
Stiiv
Date Created - Batch Encode
By conandrum in forum Video ConversionReplies: 15Last Post: 14th Nov 2013, 15:57 -
Batch processing GUI for HCEnc
By freebird73717 in forum ProgrammingReplies: 15Last Post: 20th Apr 2011, 21:31 -
Tool for VirtualDub batch processing of video files - DubJobs
By bernie79 in forum Video ConversionReplies: 6Last Post: 14th Apr 2010, 10:36 -
DeVeDe - easy, batch capable video to DVD Linux/UN*X GUI
By danboid in forum LinuxReplies: 1Last Post: 23rd Oct 2008, 18:48 -
What IDE to use to create a simple GUI for command line tool?
By freebird73717 in forum ProgrammingReplies: 10Last Post: 5th Nov 2007, 13:51
