Hi everyone.
I literally...LOST...the entire afternoon trying to make the dvd return to the first menu after the end of each title but without success.
I've tryed with ifoedit but...really...it seemed to start working (vlc play it right 1 time,because it's an...'invalid command' i think) but then fail again..
Basically the dvd was created with Xilisoft DVD Creator,when the dvd is ready it basically jump to the next title and the end of one instead of coming back to the start menu.
Can someone kindly tell me how to do this (it's a bit urgent)?
Thanks in advance
-----EDIT-----
Hhahahahahahahah ok ok ok omg sorry... [i'm completely gone now xD]
Ok...found the trick,basically before the "Jump to Video manager" command there was two command that assign the var "gm (15)" and "gm (14)"...i remove them and...now it works correctly!
In the first VIDEO_TS those var were checked with some if,probably for certain value the menu played directly the next title so,removing the commands that assigned them the new value it worked.
Thanks anyway!
Results 1 to 1 of 1
Help with making menu's!!!!
By BananaKing in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2011, 08:55 -
trying to jump over Aspect ratio menu with Pgcedit
By spiritgumm in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2009, 04:03 -
DvdAuthorGui Menu Jump & Highlight problems
By grannyGeek in forum Authoring (DVD)Replies: 5Last Post: 24th Jul 2008, 23:26 -
particular Menu-making feature
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 15th Feb 2008, 16:38 -
DVD Flick...(Making main menu with TS?)
By RobAdam in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2007, 07:29
