I have always used the main movie option and made sure the quality was 100% so there would be no transcoding/encoding. I copied the movie Kung Fu Panda 2 today and reviewed the specs using mediainfo.
I saw this...
encoded by TMPGEnc (ver. 2.524.63.181)
I have never seen this before, has something changed here lately that I am not aware of? I don't know if it was actually compressed, but the writing library TMPGEnc caught my eye.
Results 1 to 30 of 31
DVD, and I didn't think about comparing bit for bit. Let me check.
Do you have AnyDVD or DVDFab Passkey? You might run one of these to disable the copy-protection before you can use mediainfo on the files on your DVD.
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski) -
Did you experience any difference in time? Copying Kung Fu Panda 2 compared to a DVD you've copied prior to this one...
It usually takes me any where from 7 to 10 minutes for copying the main movie with only english audio. I always use mediainfo after it's complete to check everything. Never have I ever seen this before
It must be a bug or something in the newer versions. I copied it twice, same results.
Tried to play both DVDs (original and result of your copy process) on your PC? If so, do you see any differences in quality? Btw, using AnyDVD/DVDFab Passkey you might check the encoding bitrates and other stats for differences? Just to be a little surer things haven't been reencoded.
I honestly don't think it actually encoded the movie. The file size is what it should be. The video bit rates are the same as the source from what I can see. It seems more like a writing bug in the info. Just an error with the latest release.
Absolutely
A thread full of action and suspense...
Here's what I found. I took the "Vier Fäuste für ein Halleluja" DVD release. Mediainfo gave me this:
AnyDVD log
Code:Allgemein Vollständiger Name : X:\...\VTS_02_1.VOB Format : MPEG-PS Dateigröße : 1 024 MiB Dauer : 19min Modus der Gesamtbitrate : variabel Gesamte Bitrate : 7 359 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format-Version : Version 2 Format-Profil : Main@Main Format-Einstellungen für BVOP : Ja Format-Einstellungen für Matrix : ausgewählt Format_Settings_GOP : M=3, N=12 Dauer : 19min Bitraten-Modus : variabel Bitrate : 6 988 Kbps maximale Bitrate : 8 000 Kbps Breite : 720 Pixel Höhe : 576 Pixel Bildseitenverhältnis : 16:9 Bildwiederholungsrate : 25,000 FPS Standard : PAL ColorSpace : YUV ChromaSubsampling : 4:2:0 BitDepth/String : 8 bits Scantyp : Interlaced Scanreihenfolge : oberes Feld zuerst Bits/(Pixel*Frame) : 0.674 Stream-Größe : 972 MiB (95%) Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Muxing-Modus : DVD-Video Dauer : 19min Bitraten-Modus : konstant Bitrate : 224 Kbps Kanäle : 2 Kanäle Kanal-Positionen : Front: L R Samplingrate : 48,0 KHz BitDepth/String : 16 bits Video Verzögerung : -40ms Stream-Größe : 31,2 MiB (3%) Text ID : 189 (0xBD)-32 (0x20) Format : RLE Format/Info : Run-length encoding Muxing-Modus : DVD-Video Video Verzögerung : 600ms Menü
Code:Allgemein Vollständiger Name : X:\...\VTS_01_1.VOB Format : MPEG-PS Dateigröße : 1 024 MiB Dauer : 19min Modus der Gesamtbitrate : variabel Gesamte Bitrate : 7 353 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format-Version : Version 2 Format-Profil : Main@Main Format-Einstellungen für BVOP : Ja Format-Einstellungen für Matrix : ausgewählt Format_Settings_GOP : M=3, N=12 Dauer : 19min Bitraten-Modus : variabel Bitrate : 6 983 Kbps maximale Bitrate : 8 000 Kbps Breite : 720 Pixel Höhe : 576 Pixel Bildseitenverhältnis : 16:9 Bildwiederholungsrate : 25,000 FPS Standard : PAL ColorSpace : YUV ChromaSubsampling : 4:2:0 BitDepth/String : 8 bits Scantyp : Interlaced Scanreihenfolge : oberes Feld zuerst Bits/(Pixel*Frame) : 0.673 Stream-Größe : 972 MiB (95%) Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Muxing-Modus : DVD-Video Dauer : 19min Bitraten-Modus : konstant Bitrate : 224 Kbps Kanäle : 2 Kanäle Kanal-Positionen : Front: L R Samplingrate : 48,0 KHz BitDepth/String : 16 bits Video Verzögerung : -40ms Stream-Größe : 31,2 MiB (3%) Menü
DVDFab - Copy DVD and Blu-ray Disc to DVDR, BD-R, MKV and iPad/iPhone/iPod.
http://www.dvdfab.com -
Sorry for the double post, but here is the info for the first VOB.
Code:Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Duration : 24mn 53s Bit rate mode : Variable Bit rate : 5 188 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Scan order : 2:3 Pulldown Compression mode : Lossy Bits/(Pixel*Frame) : 0.626 Stream size : 924 MiB (90%) Writing library : TMPGEnc 2.524.63.181 Color primaries : SMPTE 170M Transfer characteristics : SMPTE 170M Matrix coefficients : SMPTE 170M]
I got curious and ran a DVD through DVDFab 8.1.3.8 to check with MediaInfo and it came up as:
"Writing library : TMPGEnc XPress 4.7.4.299" -
I found where the problem is: we used TMPGEnc to encode CGP VOB files.
CGP VOB files are just still images, and only used to replace the VOB cells which is not needed in output.Last edited by fengtao; 16th Dec 2011 at 10:48.
Will there be an update to fix the issue? Or is it not really worth updating over.
There isn't anything need be fixed, thanks.
Sorry guys, but it's quite routine for commercial software to be built around free / open source software. Some end users may find that shocking, and developers of the commercial programs don't like to talk about it, but it happens all the time.
In the IT community this is not viewed with alarm. Why reinvent the wheel? To programmers plagiarism is a sign of intelligence.
So personally, I don't give a damn if they used open source. It won't come up with me because I only use DVDFab HD decrypter. The encoding for converting the VOB files stinks. I use Handbrake in 2 pass mode for that.
DVDFab
By agtjones in forum AudioReplies: 6Last Post: 27th Feb 2014, 16:53 -
DVDFab 8.1.6.3
By tarzan54 in forum DVD RippingReplies: 3Last Post: 12th Feb 2012, 21:06 -
Is DVDfab still the best?
By jason in forum Newbie / General discussionsReplies: 38Last Post: 14th Jun 2009, 07:40 -
DVDFab HD Decryter
By gjordan12198 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jun 2008, 21:12 -
Dvdfab question
By nugent in forum DVD RippingReplies: 2Last Post: 26th Mar 2008, 06:37
