I get these errors at 50.3% of the only titleset to be produced on machine #1 and moved the data to machine #2 an it does exactly the same, so I don't think it is a memory error.
Version: SVCD2DVD 2.5
Build: 2.5.5030.0
Type: System.AccessViolationException
Source: SVCD2DVD
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
When I close this box, I get the following error
Build: 2.5.5030.0
Source: SVCD2DVD
InnerException:
Build: 2.5.5030.0
Source: SVCD2DVD
InnerException:
I have 41 mpg in single folder, named SV(00).mpg - SV(40).mpg. The total size of the files is 4.19 GB. They were created from vob2mpgpro, 3.2.2000, from vobs created by dvdshrink, from vobs from DVR from TV shows. They are 16:9, from HD broadcast, but I can only transfer from DVR to computer via DVD, so they get scaled up for HD monitor & TV when I play them. vob2mpg had no problem generating these file. These dvdshrink vob files play fine on VLC & PowerDVD. I am processing them only because your pair of programs does a very good job of splicing together many short clips into seamless single titleset. I have done this before - several times - mostly with the free vob2mpg. I have done this process at least once [4 titlesets w menu] w the PRO version.
I compile from 2nd option: no menu & do not burn. CPU usage is max 6%. It takes about a minute to reach the 50.3% point.
I have done this w only files (00) - (21) [621 MB total] and (00) - (10) [264 MB total], trying to get below the 50.3% point - hoping to be able to join 2-3-4 titlesets into a single title either via 2nd pass thru vob2mpg/SVCD2DVD or DVDShrink. With 21 files, it gets the same errors at 51%. With 11 files, it succeeds.
With (00)-(18) [604 MB], it fails at 52.2%.
With (00)-(17) [595 MB], it fails at 52.2%.
With (00)-(16) [591 MB], it fails at 52.2%.
With (00)-(14) [573 MB], it fails at 52.3%.
With (00)-(12) [560 MB], it fails at 52.4%.
With (00)-(11) [538 MB], it fails at 52.5%.
With (00)-(10) [264 MB], it works.
With (11) [280MB], it works.
With (11)-(40) [3.93 GB], it fails at 52.8%.
With (11-30) [131 GB], it fails at 58.0%.
With (11-20) [356 MB], it fails at 85.8%.
With (11-15) [310 MB], it fails at 91.8%.
With (11-14) [309 MB], it fails at 92.2%.
With (11-12) [296 MB], it fails at 94.4%.
With (12) [23 KB], it works.
With (12-40) [3.66 GB], it fails at 50.0%.
I noticed in these tests, the CPUs got up to 25% [I have a multi-core CPU 'gadget' on the desktop], but it is more often ~6%.
What is going on?
Can you attach your log file?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
1 - how do I get a log from SVCD 2 DVD?
2 - how do I attach it/upload it? I tried to attach an mpg to the original post, but it did not seem to work. no feedback, either. -
Ran files 10 & 11. Both OK separately, but will not link together. log attached
If your goal is to end up with one, giant MPEG file from a bunch of stuff on a DVD....my first choice would be with DVDDecrypter, IFO Mode, File Splitting: NONE.
THis is not what I am doing. These clips come from varied sources. Some of them were ripped via dvddecrypter, which is beside the point.
Firstly, sorry about the delay.
I have got the jist of what your issue is. From the log I can see that #10 has different audio properties to #11. (#11 has 3 audio stream for example). According to the DVD specs the number and type of audio and video streams in same title set must be the same. I suspect this is the issue here.
The solution is to start with the assets having the same audio streams (if coming from vob2mpg you can select a single audio stream rather than the "default" which gives you all the streams available) or split assets with different audio in to different title sets in svcd2dvd.
Does that make sense?
Regards,
ChrisSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
x264 encoding occurs too fast in pass 1
By codemaster in forum DVD RippingReplies: 5Last Post: 21st Sep 2011, 22:28 -
[Solved] Error occurs when encoding audio using megui
By ihmcjacky in forum Video ConversionReplies: 5Last Post: 17th Nov 2010, 23:24 -
SVCD2DVD Titleset Button Name Changes (when it shouldn't)
By DannoDanno in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 8th Sep 2010, 13:21 -
Creating Titleset #1 freezing
By bjproc in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Oct 2007, 10:47 -
How to figure out why during playback skipping, popping occurs
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 29th Jun 2007, 00:57
